How Is Impulse Calculated in Volleyball?
  • Thread starter ravirodrigues
  • Tags
    Impulse
In summary: I misunderstood what was being asked.The ball starts at rest, so the initial velocity will be zero.In summary, the player applies a momentum of -280g to the ball which causes it to have a final velocity of 8m/s.
ravirodrigues
Items A and B :)
F~ = (260N)ˆi − (180N)ˆj
v~ = (15m/s)ˆi−(8m/s)j
In a volleyball match a player hits a 280g mass ball with a force given by
. A force acts for 4 meters and the ball acquires a final velocity given by
. (a) What is the momentum the player has applied to ball? (b) What is the final speed of the ball?
Thank you.
ravirodrigues said:
Homework Statement:: Items A and B :)
Homework Equations:: F~ = (260N)ˆi − (180N)ˆj
In a volleyball match a player hits a 280g mass ball with a force given by View attachment 254050. A force acts for 4 meters and the ball acquires a final velocity given by View attachment 254051 . (a) What is the momentum the player has applied to ball? (b) What is the final speed of the ball?
Thank you.
Per forum rules, you need to post an attempt.
Likes hyunxu
The force acts for 4 meters! Them are some loooonnggg arms!
  • Haha
  • Wow
Likes Saptarshi Sarkar, archaic and rude man
For finding momentum, you can use the formulaP=mv
For finding final velocity , you can use , the kinematic equation v^2 = u^2+ 2as
and to find that a , use a = f ÷m
I think you mean, to find the initial velocity, u. The final velocity is given.
And the appropriate momentum formula is ##\Delta p=m(v-u)##.
Likes hyunxu
Are you supposed to assume that the initial velocity was 0?
No, it can be calculated from the given information. In fact, I wonder if part b) is supposed to ask for that; seems a bit trivial to ask for the final speed when the final velocity is a given.
Likes Kaguro
Part (b) is trivial: Just calculate the magnitude of the given ##\vec{v_f}##.
For Part (a): I keep getting a negative under the square root. :eek:
If I assume that the volleyball is being served and therefore starting at a velocity of 0, it becomes easier?
Aren't you assuming that the displacement is completely in the direction of the force?
Something isn't working out for me here.
lightlightsup said:
Part (b) is trivial: Just calculate the magnitude of the given →vfvf→.
As @Cutter Ketch pointed out in post #2, the 4m is clearly wrong, but @ravirodrigues has not come back to correct it. Probably should be 4cm. Or even 4mm.
Taking the initial velocity as zero doesn't help.
If the displacement is not in the direction of the force we do not have enough info for part a unless we do take the initial velocity as zero, but then we don't need F or the 4m.
o0):mad::headbang:
With 4cm, the math does workout.
We can consider the ball to be in rest initially so the initial velocity will be zero.
How so? It doesn't say this is the serve.
Also, please see last para in post #9.
Likes hyunxu
Yes , you're right!
What is impulse?
Impulse is a measure of the change in momentum of an object over a period of time. It is equal to the product of the force applied to an object and the time it is applied.
What is the formula for calculating impulse?
The formula for calculating impulse is I = F x t, where I is impulse, F is force, and t is time.
What is the unit of measurement for impulse?
The unit of measurement for impulse is Newton seconds (N*s).
How is impulse related to momentum?
Impulse is directly proportional to momentum, meaning that as impulse increases, momentum also increases. This is because impulse is the change in momentum over a period of time.
Can impulse be negative?
Yes, impulse can be negative if the force and change in momentum are in opposite directions. This indicates a decrease in momentum over time.
