Can anyone check my working on the friction upcoming test question
The discussion revolves around questions related to the coefficient of static friction and frictional forces in physics problems. The correct answers for the questions include that the coefficient of static friction is a dimensionless quantity expressing the ratio of limiting friction to normal reaction, and that the ratio of limiting friction to normal reaction is known as the coefficient of static friction. A participant expresses confidence in their calculations for a problem involving a skier and a ladder, detailing the forces and moments involved. They suggest an alternative method for calculating the coefficient of static friction for the ladder problem, indicating a potential error in the skier's question answer. The overall analysis appears sound, with a request for clarification on the skier's question.
cracktheegg
Question 1
Which statement is true of the coefficient of static friction?
Answer
It is the force resisting motion.
It is proportional to the static friction force.
It is a dimensionless quantity expressing the ratio of limiting friction to normal reaction.
It is the ratio of friction to normal reaction.
Question 2
The ratio of limiting friction to the normal reaction is known as
Answer
angle of friction.
angle of repose.
coefficient of kinetic friction.
Question 3
Which of the following statements is NOT true about friction?
Answer
Kinetic friction is larger than static friction.
Limiting static friction is dependent on normal reaction acting on the body.
Coefficient of friction denotes surface roughness of the bodies in contact.
Frictional force acts tangential to the surfaces in contact.
Problem sum
https://www.icloud.com/photostream/#AE5oqs3qHTNWQ;6FA15CFC-95B7-4C76-83AF-405A75919F01
1. 3rd option
2. 3rd option
3. 1st option.
Problem sums:
Where W is the skier's weight:
Force pressing skier agaist slope = W×Cosθ
Friction force in motion = 0.07×W×Cosθ ... (1)
Skier's weight component acting down the slope = W.Sinθ ... (2)
(1) and (2) are equal giving:
0.07×W×Cosθ = W.Sinθ from which:
Tanθ = 0.07 so that θ = arc-tan(0.07) = 4.0˚
Weight of ladder = 18×9.8 = 176.4 N
Weight of man = 90×9.8 = 882.0 N
Put the man at the top of the ladder
Vertical component of force between ladder and ground (normal force) =Fn= 174.6 + 882 = 1058.4 N
To find reaction of wall against the ladder take moments of all applied forces about bottom end of ladder:
(176.4×2 + 882×4).sin(30˚) = Rw×4.Cos(30˚) (Rw = reaction of wall)
Rw = (176.4×2 + 882×4).sin(30˚) / [4×Cos(30˚)]
(176.4×2 + 882×4).½ /(2.√3) = 560.2 N
The horizontal component of the reaction force between ladder and ground = Fh = Rw since all horizontal forces on the ladder must balance and there are only these two!
Necessary friction coefficient = Fh/Fn = 560.2/1058.4 = 0.529
It all looks right to me.
You should note that in the second problem, you can more easily (in my opinion) retrieve the coefficient of static friction by taking moments about the top of the ladder instead of the bottom.
\sum M_{t} = 0 = W_{L}*(L/2)*sin(30) - F_{y}*L*sin(30) + F_{x}*L*cos(30)
\sum F_{y} = 0 = F_{y} - W_{L} - W_{M}
F_{x} = μF_{y}
where F_{y} and F_{x} act on the bottom of the ladder
Solving for F_{y} and F_{x} in the force and friction equations, them plugging into the moment equation, you can solve for μ more easily
It seem that the ski question answer may be wrong according to the result i get, any clue why?
Looks ok to me...
