theone
- 81
Using the above result, estimate the annual CO2 emission savings (in kg/yr) associated with replacing one 60W incandescent bulb with one 13W fluorescent bulb, in one typical Canadian household. Do this calculation from “first principles” using the following assumptions:
(The "above result" was the answer to "How many hours per day must the replacement and original light bulb be left switched on (on average over the year) to save a certain amount of money per house". The answer was found to be 4 hours)
- The GHG savings are entirely CO2 and result from the reduced combustion of fossil fuels in electric power plants.Canada’s electrical power generation mix is 23 % from fossil fuels. Assume electricity from other sources (hydro, nuclear and renewable) have approximately zero carbon emissions. The carbon intensity of this fossil fuel usage is 22 g/MJ
- Assume the overall efficiency for the fuel energy to electrical power conversion process is 35 %
- Most light bulbs are located indoors, in an occupied living space. So, the net carbon emissions savings will be approximately zero for six months of the year.
Is the answer:
so (60-13)= 47W worth of carbon emissions is saved by replacing the bulbs,
47W=47 j/s so
47 j/s * (4hours*3600)s * 22(g /MJ) * (1MJ/10^6J) =
14.9g
since carbon savings is zero for half the year, then 14.9/2
= 7.45g?
I'm not sure where to use the info of 35% or 23%?
