Center of gravity of a plank
In summary, the plank will start to tip when the left support reaction goes to zero. To calculate the distance x that a person weighing 448 N can walk on the overhanging part of the plank, we can equate moments about the right support. This yields x = 0.56m, the distance to the right of the right support that the person must be for the plank to just start to tip. Alternatively, we can sum moments about the left support, but this is more cumbersome.
wchvball13
A uniform plank of length 4.6 m and weight 210 N rests horizontally on two supports, with 1.1 m of the plank hanging over the right support. To what distance x can a person who weighs 448 N walk on the overhanging part of the plank before it just begins to tip?
W1(x1)=W2(x2) = Xcm
W1+W2
210(3.5) + 658(1.1)
210 + 448
Xcm=1.87m
Not even sure if this is right, and I'm stuck after this. The way I understand it, once the center of gravity passes the second support, the plank will start to tip. But I don't know how to figure out how to calculate how far the person can walk before the center of gravity gets to that point.
W1(x1)=W2(x2) = Xcm
W1+W2
210(3.5) + 658(1.1)
210 + 448
Xcm=1.87m
your moment calculations are way off. Hint: The plank will start to tip when the reaction at the left support goes to zero...does that help?
I don't understand...
W1(x1)=W2(x2) = Xcg
W1+W2
Is this the wrong equation?
W1(x1)=W2(x2) = Xcg
W1+W2
I don't know what you're trying to do with this equation which has some arbitrary numbers in it. When the left support reaction goes to zero, then the moment about the right support, from the cg of the planks weight, must balance the moment about the right support from the person's weight. Equate the moments and solve for the distance from the person to the right support. As he walks beyond that point, the plank tips because the left support cannot withstand an upward load (assuming its not bolted down, in which case she'd never tip).
ok I'm still completely lost...could you maybe baby step me through this?
The first step is to recognize that the planks weight of 210N acts at its cg of 2.3m from the left support..at its midpoint. So it acts at 1.2m to the left of the right support. So now equate moments about the right support, with the knowledge that the left support provides no support at the tipping point:
210(1.2) = 448(x). Solve for x, the distance to the right of the right support that the person must be for the beam to just start to tip. I get x= .56m. Aternatively, if you like your equation better and you understand where it's coming from, then with the cg of the system at the right support, you can sum moments about the left support and come up with
(210 +448)(3.50) = 210(2.3) + 448(3.5 + x), which yields the same result in a rather cumbersome manner. So why sum about the left support when it is much easier to sum about the right support
(210 + 448)(0) = 210(1.2) - 448(x) = 0; x = .56m.
Does this help or only serve to confuse?
1. What is the center of gravity of a plank?
The center of gravity of a plank is the point at which all of the weight of the plank is evenly distributed. It is the point where the plank would balance if placed on a fulcrum.
2. How is the center of gravity of a plank determined?
The center of gravity of a plank can be determined by finding the midpoint of the plank's length and width, and then drawing a line between those points. The point where the two lines intersect is the center of gravity.
3. Why is the center of gravity important to know for a plank?
The center of gravity is important to know for a plank because it affects the stability and balance of the plank. If the center of gravity is not in the middle of the plank, it may be more prone to tipping or falling over.
4. How does the center of gravity change if a plank is tilted or rotated?
The center of gravity will change if a plank is tilted or rotated. As the plank's position changes, the weight distribution also changes, and the center of gravity will shift accordingly.
5. Can the center of gravity of a plank be outside of the actual plank?
No, the center of gravity of a plank will always be within the boundaries of the plank itself. It cannot be outside of the plank as it is a point that represents the average location of all the weight of the plank.
11K
16K
