How Do You Calculate Impulse and Force in a Racquetball Collision?
In summary, a hollow racquetball with an initial speed of 12.0 m/s collides with a backboard and rebounds with a speed of 6.0 m/s. The total impulse on the ball is 0.252 kg. m/s and the average force on the ball is -6.3 N. The negative sign indicates that the ball is moving in the opposite direction after bouncing off the wall. The units for momentum are kg. m/s, the units for velocity are m/s, and the fundamental units for a Newton are kg. m/s^2.
mememe1245
Question
A 0.0420-kg hollow racquetball with an initial speed of 12.0 m/s collides with a backboard. It rebounds with a speed of 6.0 m/s.
a. Calculate the total impulse on the ball.
b. If the contact time lasts for 0.040 s, calculate the average force on the ball.
What I did on the test:
(A)Impulse=F x change in T=change in momentum(mass x velocity)
F= unknown, so use the formula, F=M x A
_________________________
Momentum=
P(momentum)= 0.0420kg x 6m/s
P= .252N
Therefore, the impulse on the ball is, .252kg. m/s.
(B) F= Mass x Acceleration
change in Velocity= Acceleration x Time
Acceleration= change in Velocity/ Time
A= Velocity final - Velocity initial/ Time
A= 6m/s -12m/s/0.040s
A= -6m/s/0.040s
A= - 150 m/s^2
_____________
F= M x A
F= 0.042kg x (-150m/s^2)
F= -6.3 N
Chestermiller said:
(-6) - 12 = -18
Why is the "6" negative?
Because after it bounces off the wall it moves in the opposite direction.
Ohhh...Okay.
so, 18 x 0.0420kg
P = .756N?
mememe1245 said:
Ohhh...Okay.
so, 18 x 0.0420kg
P = .756N?
Are you sure about the units of P (if you indeed mean that P is the impulse of the force)?
Chet
Chet
Nm
mememe1245 said:
Nm
No. You're just guessing.
What are the units of mass? What are the units of velocity? What are the fundamental units of a Newton?
Chet
What is the definition of momentum?
Momentum is a measure of an object's motion and is calculated by multiplying its mass by its velocity.
What is the equation for change in momentum?
The equation for change in momentum is Δp = mΔv, where Δp represents the change in momentum, m is the mass of the object, and Δv is the change in velocity.
How do you calculate the change in momentum in a problem?
To calculate the change in momentum, you need to know the initial and final velocity of the object, as well as its mass. Then, you can use the equation Δp = mΔv to find the change in momentum.
What is the unit of momentum?
Momentum is typically measured in kilogram-meters per second (kg·m/s).
How does Newton's second law relate to change in momentum?
Newton's second law states that the net force acting on an object is equal to the rate of change of its momentum. This means that if there is a change in momentum, there must be a force acting on the object.
