Comparing Mass: 100 kg of Goose Feathers vs. 100 kg of Mass - Explained
  • Thread starter easydoesit
  • Tags
    Mass
In summary: Originally posted by Adrian Baker The SI unit for Mass is Kg, the Imperial unit is the pound. The SI unit for weight is the Newton, the Imperial unit is the pound-force, not the pound.
easydoesit
100 kg of goose feathers or 100 kg of mass and why[?]
Kilograms are a measure of mass.
cookiemonster
Obviously, 100 kg of anything is going to have the same mass as 100kg of anything.
I asked this in another thread: How much does a 150lb man weigh on the moon?
Earth pounds or Moon pounds?
cookiemonster
Mass and wieght are two entirely different things.
A 150 lb man would weight about 25 lb on the moon. But he would still mass 150 lb.
Weight is a force and should be measured in Newtons, not in lb.
The SI unit for mass is Kg
The SI unit for weight may be the Newton, but it's perfectly legit to use the pound (lb) for weight. If someone uses the pound to describe an object's weight and not the Newton, so be it, there's nothing objectable to that. You can very easily switch between pounds and Newtons with a simple conversion, anyways.
You can't use the pound for both mass and weight - they are completely different quantities!
It entirely depends on what Unit system you are using.
In the absolute FPS system, the unit of force is the poundal and the unit of mass is the pound.
In the gravitational FPS system, the unit of force is the pound and the unit of mass is the slug.
In the American Engineering Standard, the pound is used for both mass and force. (sometimes designated as lbm and lbf , but many times you are just supposed to know what it is being used for by context.)
cookiemonster
Exactly...
That's if he weighed 150lb on earth...who said anything about what he weighs on earth? :wink:
In the US we do - layman and engineers alike. Heck, if you make your bathroom scale read in kg, its using kg as weight!
For more on lb vs kg, etc, see THIS thread in the General Engineering forum.
[/shameless plug]
No wonder NASA sent a probe to Mars that missed completely as someone had used the wrong units for thrust calculations! :smile:
Actually, there are situations where pounds (force) and pounds (mass) are both used. For example, calculating specific impulse.
Specific impulse is a unit that describes the amount of thrust that is achieved per mass of fuel consumed per second.
In SI the units of specific thrus are:
Newtons / (Killograms/Second) = Meters Per Second.
(This is accurate since specific impulse is essentially determined by the relative velocity of the rocket exhaust.)
In standard the units of specific thrust are:
(Pounds (force))/(Pounds (mass)/Second)= seconds
Related to Comparing Mass: 100 kg of Goose Feathers vs. 100 kg of Mass - Explained
1. What is the difference between mass and weight?
Mass refers to the amount of matter an object contains, while weight is the measure of the force of gravity acting on an object's mass. In other words, mass is a constant property of an object, while weight can vary depending on the strength of the gravitational pull.
2. How can 100 kg of goose feathers and 100 kg of mass be compared?
When comparing mass, it is important to consider the density of the objects. While both 100 kg of goose feathers and 100 kg of mass have the same value in terms of mass, their volume and density will differ. This means that the 100 kg of goose feathers will take up more space and have a lower density compared to the 100 kg of mass.
3. Why is it important to understand the concept of mass?
Understanding mass is crucial in various scientific fields, such as physics and chemistry. Mass is a fundamental property of matter and plays a role in many physical and chemical processes. It is also an essential factor in determining the behavior of objects under the influence of forces, such as gravity and friction.
4. How is mass measured?
Mass is typically measured using a balance or scale. These tools use the principle of equilibrium to determine the mass of an object by comparing it to a known mass. The most common unit of mass is the kilogram (kg) in the metric system, but other units such as pounds (lb) and grams (g) are also used.
5. Can mass be converted into other units?
Yes, mass can be converted into different units depending on the system of measurement used. For example, in the metric system, 1 kg is equivalent to 1000 g, while in the imperial system, 1 lb is equal to 16 oz. It is important to note that the mass itself does not change, only the unit of measurement being used.
  • Other Physics Topics
