hackhard
- 183
- 15
since magnetic field lines form closed loops , field inside Earth must be due geographic south
will compass below Earth's surface point to geographic south?
A compass below earth surface is a tool used to determine direction underground, where traditional compasses do not work due to the influence of magnetic minerals in the earth.
A compass below earth surface works by using a magnetized needle that aligns with the earth's magnetic field. This allows the user to determine the direction of north and orient themselves accordingly.
A compass below earth surface is important for navigation and exploration in underground environments such as caves, mines, and tunnels. It allows individuals to find their way and avoid getting lost.
A compass below earth surface may not work in areas with high levels of magnetic interference, such as near metal objects or power lines. It also requires a steady hand and may be affected by movement or vibrations.
Yes, there are alternative methods for determining direction below earth surface, such as using a gyrocompass or celestial navigation. However, these methods may be more complex and require specialized equipment or knowledge.
