Conservation of Momentum in a Single Direction
In summary, the Law of Conservation of Momentum states that the total linear momentum does not change in any closed system not subject to external forces. This applies to all directions, including the x-direction, as long as there are no forces acting in that direction. While it may seem confusing, this is because momentum is a vector quantity and can be broken down into components in any direction. In the case of a collision between a bowling pin and a ball, the momentum in the x-direction is conserved, even though both objects end up moving in the y-direction. This is due to the vector equations and the fact that momentum is a product of mass and velocity.
JSGandora
95
The Law of Conservation of Momentum states that the total linear momentum does not change in any closed system not subject to external forces. However, is it true that the momentum in, say, the x-direction does not change in any closed system not subject to forces in the y-direction?
I feel that it is indeed true since y-directional forces do not change the x-directional velocity, thus conserving momentum in the x-direction.
Hi JSGandora! :smile:
JSGandora said:
… is it true that the momentum in, say, the x-direction does not change in any closed system not subject to forces in the y-direction?
(you mean "not subject to forces in the x-direction")
Yes.
Conservation of momentum comes from the vector equation change of momentum = ∑ external forces.
Since this is a vector equation, you can take components in any direction, and if the component of ∑ external forces in that direction is 0, then the change of momentum in that direction is also 0. :wink:
Likes 1 person
It does get a bit confusing. Think about a bowling pin at rest, and when you throw a ball at it (at a slight angle) the ball hits the pin, and they both fly off in the xy plane. So before the collision, the momentum in the x direction is whatever the mass of the ball is times the velocity. In the y direction, it's zero.
But after the collision, both objects move in the y direction…how does that work out? Well, consider the vector equations. The mass times the speed of the object moving "upwards" cancels out with the mass time sthe speed of the object moving "downwards".
Remember that momentum is a vector quantity since it's mass times Velocity.
P.S. are you from aops? :)
Likes 1 person
Related to Conservation of Momentum in a Single Direction
What is conservation of momentum in a single direction?
Conservation of momentum in a single direction is a fundamental law in physics that states that the total momentum of a system remains constant in the absence of external forces. This means that the total amount of motion in a specific direction will remain the same unless acted upon by an external force.
What is the equation for conservation of momentum in a single direction?
The equation for conservation of momentum in a single direction is: p1 + p2 = p1f + p2f where p1 and p2 are the initial momenta of two objects and p1f and p2f are their final momenta after a collision or interaction.
How does conservation of momentum in a single direction apply to real-life situations?
Conservation of momentum in a single direction can be observed in many real-life situations, such as collisions between objects and interactions between particles. For example, when a billiard ball hits another ball, the total momentum of the two balls before and after the collision remains the same, even though the direction and speed of each ball may change.
What are some factors that can affect conservation of momentum in a single direction?
Some factors that can affect conservation of momentum in a single direction include external forces, such as friction or air resistance, and the mass and velocity of the objects involved. In a closed system with no external forces, conservation of momentum in a single direction will always hold true.
Why is conservation of momentum in a single direction important in physics?
Conservation of momentum in a single direction is important in physics because it is a fundamental law that helps us understand and predict the behavior of objects in motion. It is also a key concept in the laws of motion and plays a crucial role in many areas of physics, such as mechanics, thermodynamics, and astrophysics.
  • Mechanics
14K
