Convergence of this sequence .
In summary, the limit of 10n/n! as n approaches infinity is 0. The approach using L'Hospital's rule was incorrect as the factorial function dominates and the limit is actually equal to 0.
bs vasanth
find the limit n[itex]\rightarrow[/itex]∞ of 10n/ n!
L hospital rule
took log and separated the num and denom as:
n ln10-ln(n!)
n ln10-n ln(n)+n
1/n ( ln10 - ln(n)+1)
now i applied l hospital rule
then i got lim n[itex]\rightarrow[/itex]∞ as 0.So the actual answer is 1. (e0)
I just want to know if the approach is correct.
bs vasanth said:
n ln10-n ln(n)+n
I'm afraid I don't see how you transition between these two steps.
Also, intuitively the factorial function should dominate and the limit should be zero.
my bad ,in my desperate attempt to get a ratio, I did that stupid thing. How do we solve it beyond intuition?
From n ln10-n ln(n)+n, you can combine all the terms into a single expression. Taking the limit, you will find that the expression tends to minus infinity. The limit of the original expression is then 0.
n*ln(10e/n) this is what i am getting , and it is not -infinity .
Yes, the limit of that is -infinity. n goes to +infinity. What does ln(10e/n) do?
I took n out , then
n( ln10-lnn +1 )
n(ln10-lnn+lne)
n ln(10e/n)
i don't know what to do after this.
Are you saying that ln0 is taken as -inf, but there is also n before that right which becomes +inf.
The ratio test gives: [itex]a_{n+1}/a_n= (10^{n+1}/(n+ 1)!)(n!/10^n)= (10^{n+1})/10^n)(n!/(n+1)!)= 10/(n+1)[/itex] goes to 0 as n goes to 0. Strictly speaking, the ratio test shows that [tex]\sum a_n[/tex] converges but if that is so, then, of course, the sequence [itex]\{a_n\}[/itex] converges to 0.
(The converse is not necessarily true. For example, [itex]\{1/n\}[/itex] clearly converges to 0 but the sum [tex]\sum 1/n[/tex] does NOT converge so the ratio test does not work.)
n*ln(10e/n) if n is really big is a really big positive number multiplied by a really big negative number. What is that going to be?
Likes 1 person
Now i get it , it is going to really big negative number, so -inf.
therefor the answer for the original question is 0.
thankyou everyone.
Related to Convergence of this sequence .
1. What is the definition of convergence in a sequence?
The term "convergence" in a sequence refers to the idea that as the sequence progresses, the elements of the sequence get closer and closer to a specific value, known as the limit. In other words, the sequence approaches and eventually reaches a certain value.
2. How do you determine if a sequence is convergent or divergent?
A sequence is convergent if the elements of the sequence approach a specific value, known as the limit. To determine if a sequence is convergent, you can use various tests such as the limit comparison test, the ratio test, or the root test. If the limit of the sequence exists and is a finite value, then the sequence is convergent. If the limit does not exist or is infinite, then the sequence is divergent.
3. Can a sequence have more than one limit?
No, a sequence can only have one limit. This is because the limit of a sequence is a unique value that the elements of the sequence approach as it progresses. If a sequence has more than one limit, it would mean that the elements are approaching different values, which is not possible in a convergent sequence.
4. How does the convergence of a sequence relate to its rate of growth?
The convergence of a sequence is closely related to its rate of growth. A sequence that converges quickly has a faster rate of growth, while a sequence that converges slowly has a slower rate of growth. This is because the limit of a sequence is dependent on the elements of the sequence and how quickly they approach the limit value.
5. Can a divergent sequence ever become convergent?
Yes, a divergent sequence can become convergent. This can happen if the sequence is modified in some way, such as by taking the absolute value or raising the elements to a power. By altering the elements of the sequence, it is possible to change the behavior of the sequence and make it converge to a specific limit.
