Are Cosmic Rays Impacting the LHC Measurements Beyond Muons?
In summary, the conversation discusses the potential impact of cosmic rays on measurements at the LHC, specifically focusing on muons as a potential source of background. It is noted that muons have a longer range than electrons and were used to test the detectors' efficiency before the LHC was fully operational. Additionally, the differences between muons and electrons in terms of their energy loss and production in the upper atmosphere are discussed. However, the conversation concludes that cosmic muons can still be useful in aligning detector elements before the first collisions occur.
JoePhysicsNut
35
I've heard of cosmic rays affecting measurements made at the LHC in the context of muons. Is it just muons that can reach the detectors or is there background from other particles as well? Why are muons a background but not electrons? How significant is it?
Thanks.
Muons have a longer range than electrons, however I don't see how cosmic ray muons could be responsible for a significant background in the LHC, since the detectors by design are very sensitive to direction and time of arrival.
However there was a period before the LHC was fully operational in which data from cosmic rays was used to test the detectors efficiency.
The rate of cosmic muons is low compared to the rate of muons from the collisions, and muons produced in the LHC mainly come from the small interaction region, while cosmic muons travel in random directions.
Muons are heavier than electrons, so they lose less energy in matter. In addition, pion decays in the upper atmosphere mainly produce muons, not electrons.
Well, neutrinos can reach them, too, but they are not an issue as their reaction probability is so tiny.Cosmic muons are nice to align the detector elements before the first collisions are available - they go in a straight line, and you can see which detector elements are hit and find out where they are based on that.
Thanks to you both!
1. How do cosmic rays affect the LHC?
Cosmic rays are high-energy particles that originate from outer space and can sometimes collide with the LHC's beams. These collisions can create secondary particles that can interfere with the LHC's operations and potentially damage its components.
2. Can cosmic rays cause malfunctions or accidents at the LHC?
While cosmic rays can cause disruptions in the LHC's operations, the facility is equipped with robust safety measures to prevent any accidents. These include shielding and monitoring systems that can quickly detect and mitigate any potential risks.
3. How does the LHC protect itself from cosmic rays?
The LHC has several layers of protection against cosmic rays. First, there are physical barriers and shielding in place to reduce the number of cosmic rays that can reach the facility. Additionally, there are advanced detection and monitoring systems that can identify and mitigate any potential disruptions caused by cosmic rays.
4. Are there any benefits of cosmic rays for the LHC's research?
While cosmic rays can interfere with the LHC's operations, they also provide valuable insights into the nature of high-energy particles. Scientists use the data from cosmic ray collisions to better understand the behavior and properties of particles that are similar to the ones produced by the LHC.
5. How does the LHC handle cosmic rays during experiments?
The LHC has sophisticated monitoring systems that can detect the presence of cosmic rays during experiments. If cosmic rays are detected, the LHC can pause the experiment and resume once the interference has subsided. Additionally, scientists can also filter out any data that may have been affected by cosmic rays during the data analysis process.
  • DIY Projects
