Crying babies sound question
  • Thread starter toesockshoe
  • Tags
    Sound
In summary, the sound intensity level is 6 decibels greater when four quadruplets cry simultaneously compared to when a single one cries, as it is equivalent to doubling the power of the sound. This is calculated using the formula B=10*log(I/I_0), where I_0 is an arbitrary reference, and taking into account that the sound sources are not coherent.
toesockshoe
265
When four quadruplets cry simultaneously, how many decibels greater is the sound intensity level than when a single one cries?
B=10*log(I/I_0)
[/B]
I_0 is arbitrary (its just a reference).
When 4 babies cry, I would assume that it is the equivalent of 4 sound sources. Thus the amplitude would be 4 times larger than a single sources (or single crying baby)
Because intensity is proportional to amplitude square, I would assume I/I_o is 16... Putting this into the formula: 10*log(16/1) is 12. The solutions say to do 10*log(4/1) which equals 6 implying that the intensity is only 4 times as great.
B=10*log(I/I_0)
[/B]
You don't need to do the square thing. If you add two signals, you get double the intensity. The first double gives you +3dB,and the second double (to get you to 4 times) gets you to +6dB. :smile:
what? if you add 2 signals, i thought you get 4 times the intensity...
If that's the case, why is it that in a double slit, the central max is 4 times as a single light ray? We also do this using phasor diagrams. Where each additional source of light (or this case sound) represents adding a vector and the combined total length is the total amplitude. We square this to get the intensity.
The double-slit has the light rays in phase at the maximum, so you get double the peak electric field and 4x the power at that peak location. But the sound intensity in this problem is not coherent, so double the sources gives double the power.
do you mind explaining by what you mean when you say "the sound intensity in this problem is not coherent"?. thank you.
Sure. In the double-slit example, at the bright spot the E fields are in phase, hence twice the E field gives 4 times the intensity.
But with sound or light waves that are not in phase, you get a doubling of intensity when you double the number of sources. The waves add in an RMS fashion because there are multiple frequencies and phases. Think about if you have two flashlights, you get twice the brightness as compared to just one flashlight...
ok, so were basically saying it averages out to twice the intensity right?
Yes, when you add the RMS powers of two sources, you get twice the RMS power. :smile:
oh ok. thank you.
What causes crying in babies?
Babies cry for various reasons, including hunger, discomfort, fatigue, overstimulation, and general need for attention or comfort. They may also cry due to physical discomfort such as diaper rash or teething pain.
How do I soothe a crying baby?
To soothe a crying baby, try swaddling them in a soft blanket, rocking or gently bouncing them, singing or playing soothing sounds, or offering a pacifier. It may also help to try different positions, such as holding the baby upright or on their side, and to check for signs of discomfort or hunger.
Is it normal for babies to cry a lot?
Yes, it is normal for babies to cry frequently, especially in their first few months of life. Crying is their way of communicating their needs, and it can also be a way for them to release tension or express emotions. However, if your baby is crying excessively and you are concerned, it is always best to consult with a pediatrician.
Why do some babies cry more than others?
Every baby is unique and may have different levels of sensitivity, temperament, and needs. Some babies may be more easily soothed, while others may be more reactive to stimuli and have a harder time self-regulating. Additionally, factors such as colic, reflux, or food intolerances can also contribute to excessive crying in some babies.
At what age do babies stop crying so much?
Babies' crying patterns tend to decrease as they grow and develop more ways to communicate their needs. By 3-4 months, babies may cry less and have more predictable patterns of sleeping and eating. However, every baby is different, and some may continue to cry more than others even after this age. If you have any concerns about your baby's crying, it is best to consult with a pediatrician.
  • Classical Physics
