Telis
- 2
- 1
In Griffith's "Introduction to Electrodynamics" says that in a bar electret the curl of the polarization does not equal zero everywhere. Why is that ? Thanks in advance
The curl of polarization in a bar electret refers to the rotation of electric polarization within the electret material. This rotation is caused by the presence of an external magnetic field.
The curl of polarization can be measured by observing the change in electric polarization within the electret material when exposed to a varying magnetic field. This change can be measured using specialized equipment such as a magnetometer.
The curl of polarization in a bar electret is caused by the alignment of electric dipoles within the material in response to an external magnetic field. This alignment results in a rotation of the electric polarization within the material.
The curl of polarization in a bar electret has various applications in fields such as sensors, actuators, and data storage. It is also used in devices such as magnetic field sensors and magnetic recording heads.
Yes, the curl of polarization in a bar electret can be controlled by varying the strength and direction of the external magnetic field. This allows for precise manipulation of the electric polarization within the material, making it useful for various applications.
