Current flow evenly in a conductor?
In summary, current flows uniformly in a conductor when the frequency of the signal is low, but it becomes concentrated in certain areas when the frequency of the signal is higher.
PhiowPhi
203
When current flows in a conductor, is it evenly spread out in the conductor? Not flowing(concentrated) in a certain part? And if we split the conductor into smaller pieces(visually not physically) the current divides out evenly so that when all those split pieces add up it equals the same as the whole piece?
No. Consider - the current consists of lots of same-sign charges on the move. Those charges will all repel each other won't they? So where will they tend to be concentrated?
Likes daviemmanuel
Well, I assumed they would be all spread out evenly, I can't think of a particle area they will be in a conductor(if not "all around") the edges then?
I assumed they would be all spread out evenly,...
Yes but how?
When you draw electrostatic charges on a conductor, where do you normally draw them?
I went back and studied some old diagrams, of potential difference and the electric field produced on a conductor, I think... the electrostatics charge is spread out evenly on the edge of the conductor(bottom + and top - charges or vice versa), like this diagram:
Your question was about where the charges are while they are traveling as part of the current - that diagram does not tell you that.
But you have drawn the situation where there is a static charge distribution on a conductor and no applied electric field.
Where do you normally draw the charges?
Try sketching that case for a long cylinder.
The way I understand it, the uniformity with which the current distributes over the cross section of the conductor depends on the frequency of the signal.
For DC (direct current) or 0 Hz, the current carrying particles (electrons) tend to more evenly distribute over the entire cross section of the conductor.
When the signal starts being an oscillating, alternating one (AC), you introduce a changing magnetic field (induced electric field, induced currents, etc) ; when this happens, the electric current start by not using the center of the conductor and instead start crowding towards the outer layers of the conductor. With higher frequencies, the larger the "empty" inner area of the conductor and the thinner the outer layer effectively being used for carrying current. Research "skin effect".
So, for the case of alternating current, the answer is no...if you divide the conductor into wires, the current is not equally distributed...the wires from the center of the conductor could even be thrown away with no detectable effect other than material cost/weight savings.
Likes PhiowPhi, daviemmanuel and davenn
Well, it's a boundary-value problem of electrodynamics. For normal household DC, it's a good approximation to assume a homogeneous current density in the wire. Note that you can solve the infinite-length coax cable analytically, and that this is not done in most textbooks although you gain a lot of insights (also concerning energy flow). The best treatment of the problem I know is in
A. Sommerfeld, Lectures on Theoretical Physics, Vol. 3.
For AC you can treat the coax cable also analytically for the full Maxwell equations as a paradigmatic example for a wave-guide problem.
Likes PhiowPhi
We are not talking about excess free charge placed on a conductor (like a capacitor plate) which will move to the outside, the charge in a neutral (but conductive) wire is simply due to the charge carriers, and is completely neutralised over macroscopic scales by the positive ionic lattice. So you shouldn't see charge move to the outside for a simple wire due to any electrostatic effect.
However, the way those charges move is not necessarily balanced. If your wire has a kink, you will see a concentration of the current density at the inner part of the kink, like a car taking a 'racing line', because it is a path of less resistance to ground. As others have said, you also have a large concentration of current density to the outer surface with AC, which is an inductive effect.
But for a linear conductor excited by DC, the current density is indeed spread out homogeneously over any cross-section that is perpendicular to the direction of current.
"There’s a great discussion in Griffiths book on electromagnetism (typical book used for junior/senior course for physics majors) about what happens to free charges inside a conductor. He discusses how they will always find their way to the surface, distributing themselves to cancel the field inside the conductor. If they don’t do that, there will be a residual field to push more charges around. This happens until the field is totally cancelled. In a footnote he mentions how this surface effect only happens in 3D. In lower dimensions, like charges on a plate, say, the charges don’t necessarily go to the boundary."
https://arundquist.wordpress.com/2011/09/17/free-charges-in-conductors/
Related to Current flow evenly in a conductor?
1. What is current flow and how does it occur in a conductor?
Electric current is the flow of electric charge, typically carried by electrons, through a material. In a conductor, such as a metal wire, the electrons are free to move, and an electric field applied to one end of the material causes a net flow of electrons towards the other end, resulting in current flow.
2. Why does current flow evenly in a conductor?
In a conductor, electrons are free to move and are not bound to any particular atom. This means that when an electric field is applied, the electrons can move freely and distribute themselves evenly throughout the material, resulting in an even flow of current.
3. Are there any factors that can affect the even flow of current in a conductor?
Yes, there are several factors that can affect the even flow of current in a conductor. These include the temperature of the conductor, the material of the conductor, and the presence of impurities or defects in the conductor's structure.
4. How does the thickness of a conductor impact the even flow of current?
The thickness, or cross-sectional area, of a conductor does not directly affect the even flow of current. However, a thicker conductor can handle a larger current without overheating, which can impact the even flow of current. Thinner conductors may have higher resistance, which can cause uneven flow of current.
5. Does the direction of current flow impact the evenness of current in a conductor?
No, the direction of current flow does not affect the evenness of current in a conductor. As long as the electric field remains constant, the electrons will continue to flow evenly in the same direction. The direction of current flow is simply a convention and does not impact the physics of current flow.
  • Electromagnetism
  • Classical Physics
  • Electromagnetism
