Difference between instantaneous velocity and acceleration
In summary: Instantaneous velocity and acceleration are not the same thing. Instantaneous velocity is the velocity at a specific point in time, while acceleration is the rate at which velocity changes over a period of time. So, they are related but not the same. It's reasonable to be confused about the two, but understanding the concept of time intervals and their effect on these values can help distinguish between them. In summary, instantaneous velocity is the velocity at a specific point in time, while acceleration is the rate at which velocity changes over a period of time. They are related but not the same, and it's important to understand the concept of time intervals in order to differentiate between them.
otownsend
Member advised to use the homework template for posts in the homework sections of PF.
Hi,
I'm just beginning to learn physics on my own. It seems that instantaneous velocity and acceleration are the same thing. Is it reasonable for me to be confused about the two? If acceleration = final velocity - initial velocity / change in time ... then how this any different from instantaneous velocity? I know that there units are different, but the equation and overall concept seems the same to me.
- Olivia
I'm not sure where you have got that idea from. Acceleration is rate of change of velocity.
Okay. Then what is instantaneous velocity?
Instantaneous velocity is simply velocity.
Acceleration is the rate which velocity changes over a time interval, or as you know, [itex]\frac{\Delta V}{\Delta s}[/itex]. As for instantaneous velocity, it is, as the name suggests, the velocity on a specific time interval (in which we take [itex]t[/itex] to be infinitely close to [itex]0[/itex]). So, for instance, even if there is no acceleration on the movement in question (that is, velocity is constant), you can still determine its instantaneous velocity, but of course, it'll be the same for the entire trajectory, given that there is no acceleration. Do you understand?
This is not very helpful.
Velocity is rate of change of displacement, and acceleration is rate of change of velocity.
If you want to talk about average velocity and average acceleration that is different. That requires a time interval.
You're right. My mistake.
Likes PeroK
Related to Difference between instantaneous velocity and acceleration
What is the difference between instantaneous velocity and acceleration?
Instantaneous velocity refers to the rate of change of an object's displacement at a specific point in time, while acceleration refers to the rate of change of an object's velocity at a specific point in time.
How are instantaneous velocity and acceleration related?
Instantaneous velocity and acceleration are related by the derivative of position and velocity, respectively. This means that acceleration is the rate of change of velocity, and velocity is the rate of change of position.
How can instantaneous velocity and acceleration be calculated?
Instantaneous velocity can be calculated by taking the derivative of an object's position function with respect to time. Similarly, instantaneous acceleration can be calculated by taking the derivative of an object's velocity function with respect to time.
What are the units of instantaneous velocity and acceleration?
The units of instantaneous velocity are distance per time (e.g. meters per second), while the units of acceleration are distance per time squared (e.g. meters per second squared).
How do instantaneous velocity and acceleration differ from average velocity and acceleration?
Instantaneous velocity and acceleration refer to the values at a specific point in time, while average velocity and acceleration refer to the average values over a given time interval. Instantaneous values can vary greatly within a given time interval, while average values provide an overall picture of an object's motion.
