Do Carmo's book, chap2 Regular surfaces, definition 1.2 -- question
The intersection of two surfaces can have a lower dimension depending on the surfaces and how they intersect. In summary, the conversation is discussing the confusion around a homeomorphism between two spaces with different dimensions. The expert explains that the intersection of the two surfaces does not necessarily have the same dimension as the two individual spaces.
Jianphys17
66
On chapter over regular surfaces, In definition 1 point 2. He says that x: U → V∩S is a homeomorphisms, but U⊂ℝ^2 onto V∩S⊂ℝ^3. I am confused, how can it be so!
What's wrong with that?
The fact that U ⊆ℝ^2 but V∩S⊆ℝ^3. How can there be a homomorphism between these two spaces, the dimensions are different ! :confused:
##\mathbb{R}^3## has dimension 3, but ##V\cap S## has dimension 2##.
Sorry, but U⊂ℝ^2 and p∈S⊂ℝ^3, with neighborhood V⊂ℝ^3. But for homeomorphism definition, |U| ≠ |V∩S| as can be ?
##U## and ##V\cap S## have the same number of elements and the same dimension.
I had realized that dim(V∩S) = 3.
Anyway thanks for the help.
It doesn't have dimension 3.
Likes Jianphys17
1. What is the definition of a regular surface according to Do Carmo's book?
The definition of a regular surface according to Do Carmo's book, chap2 Regular surfaces, definition 1.2, is a subset of Euclidean space that is locally diffeomorphic to an open subset of a plane.
2. What does it mean for a surface to be locally diffeomorphic?
A surface being locally diffeomorphic means that for every point on the surface, there exists a neighborhood around that point that can be mapped onto a neighborhood on a plane in a smooth and differentiable manner.
3. How is a regular surface different from a smooth surface?
A regular surface is a subset of Euclidean space that is locally diffeomorphic to an open subset of a plane, while a smooth surface is a subset of Euclidean space that is continuously differentiable. Essentially, a regular surface is a type of smooth surface that is also locally diffeomorphic.
4. Can a regular surface have sharp edges or corners?
No, a regular surface cannot have sharp edges or corners. It must be smooth and continuously differentiable in order to be considered a regular surface.
5. What are some examples of regular surfaces?
Examples of regular surfaces include spheres, cylinders, planes, tori, and cones. Basically, any surface that can be locally mapped onto a plane in a smooth and differentiable manner can be considered a regular surface.
  • Differential Geometry
