Does a Constantly Moving Charge Produce a Constant Magnetic Field?
Dikshant
A charge moving with constant velocity, does it create a constant magnetic field or varying 1??
What do you think?
I don't have any idea
lep11 said:
What do you think?
Help me pleasez
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
