eq1
- 206
- 71
I had an experiment I was working on where I needed to know the temperature of a circuit element down to 10uS time resolution.
I had a thermistor handy, so I thought I would attach it to the element, force a constant current into it, and look at the voltage change on a scope. This would give proper temperature and time resolution, but then I happened to think, just how fast is a thermistor? Or, for the thermistor transfer function R/T what is the gain/phase vs. frequency? I did some quick googling and got nowhere. All the vendor datasheets and notes show time series data with the time axis having second gridlines. Then I was thinking of buck circuits which use an NTC in their compensation, and those are stable, so maybe it's less than 10KHz (or something), so I just switched to measuring temperature with a diode, which I know is fast but loses temperature resolution due to the log scale. But speed is more critical for this experiment, so it works.
But the question has remained in my head. How fast is a thermistor? It seems like must depend on the package. A 0201 thermistor should be faster than a 2512 due to its smaller mass, no? And a PTC is likely different than an NTC. I was thinking when this setup is all done, which is definitely some time from now, I would redo the measurement with a Vishay 0402 NTC, which I often see used in regulators, and compare to the diode. That could give a rough estimate.
