How to Calculate Drag from Matlab Code Using Blade Element Theory?
In summary: Best of luck with your project.In summary, you are trying to estimate the Thrust and Torque generated by a propeller blade using the Blade Element Theory. You have been able to calculate the lift but not the drag. To calculate the drag, it is important to consider both the induced drag and profile drag separately. The induced drag can be calculated using the formula D = L^2/(pi*AR*e), and the profile drag can be calculated using the formula D = 0.5*rho*Cd*A*V^2. It is also important to define the variable "Cr" in your code. Additionally, it is possible to take the real part of a complex number in calculations, but it
Thusithatck
I am trying to estimate the Thrust and Torque generated by a propeller blade by utilising the Blade Element Theory. I was able to get Lift but not Drag. Below is the code generated by Matlab.
The calculation procedure is,
T1 = twist pitch ratio
RTheta = root pitch angle
Phi = atan(V/(Omega*r))
ro = 1.225 (density)
C = 0.15 m
Cdo = 0.008 (zero lift drag)
Alpha = RTheta + T1*r - Phi
Here the twist is negative which makes the tip to have a small pitch angle.
for i = 1:3:132 % Forward Speed of the Aircraft
for j = 1:3:39 % rps (rpm/60)
syms r
omega(j) = 2*pi*j;
W2(i,j) = i^2 + (omega(j)*r)^2;
Alpha(i,j) = deg2rad(RTheta) + deg2rad(T1)*r - atan(i/(omega(j)*r));
CD(i,j) = Cdo + K*(a*Alpha(i,j))^2;
W2CD(i,j) = expand (W2(i,j)*CD(i,j));
Drag(i,j) = double(0.5*ro*Cr*int(W2CD(i,j),r,Hr,D/2));
end
end
As the calculation is run, I always gets a message saying below details,
? Error using ==> sym.maple at 87
Error, (in IntegrationTools:-Utils:-Simplify) too many levels of recursion
Error in ==> sym.int at 51
r = reshape(maple('map','int',f(:),[x.s '=(' a.s ')..(' b.s ')']),size(f));
Error in ==> New at 74
I would like to know how to get the drag values. I have tried every possible method, but I still get this message.
Furthermore, independent to the above question, is it OK to get the real part of a complex number to calculations?
Say if,
R = 2*D
where,
D = 0.45 + 09i
and if you take only the real number then,
R = 0.90
Is it correct? or possible? if so or not, is there is an exception where you can take R=0.90?
Advice me on both questions please. Thank you in advanced
Thank you for your question. I understand that you are trying to estimate the Thrust and Torque generated by a propeller blade using the Blade Element Theory, and you have been able to calculate the lift but not the drag. I have reviewed your code and have some suggestions to help you get the drag values and also some general advice for your calculations.
Firstly, for calculating the drag using Blade Element Theory, it is important to consider the induced drag and profile drag separately. The induced drag is caused by the lift generated by the blade and is dependent on the angle of attack. The profile drag is caused by the friction of the air against the blade surface and is dependent on the airfoil shape and the airspeed. Therefore, your code should include separate calculations for both types of drag.
To calculate the induced drag, you can use the formula D = L^2/(pi*AR*e), where D is the induced drag, L is the lift, AR is the aspect ratio of the blade, and e is the Oswald efficiency factor. This formula can be implemented in your code by using the lift values that you have already calculated and the aspect ratio of the blade can be determined based on the blade geometry.
For the profile drag, you can use the formula D = 0.5*rho*Cd*A*V^2, where D is the profile drag, rho is the air density, Cd is the drag coefficient, A is the reference area of the blade, and V is the airspeed. The drag coefficient can be determined based on the airfoil shape and can be found in literature or by conducting wind tunnel experiments. The reference area of the blade can be calculated based on the blade geometry.
Additionally, I noticed that you are using the variable "Cr" in your code, but it is not defined anywhere. I assume it is the chord length of the blade, which is also needed for calculating the drag.
Regarding your second question, it is possible to take the real part of a complex number in calculations, but it is important to consider if it is appropriate for the specific situation. In the case of your example, if the imaginary part represents a physical quantity, then it would not be correct to only consider the real part. It would be best to consult with a mathematician or a colleague familiar with the specific problem to determine the appropriate approach.
I hope this helps you in your calculations. If you have any further questions, please do
1. How do you calculate drag using Matlab?
To calculate drag using Matlab, you can use the drag equation which is: Drag = 1/2 * Density * Velocity^2 * Drag Coefficient * Area. You will need to input the air density, velocity, drag coefficient, and area of the object in order to get the drag force.
2. Can I use Matlab to visualize the drag force?
Yes, you can use Matlab to create graphs and plots to visualize the drag force. You can plot the drag force over time or compare the drag force of different objects. This can help to better understand the effects of drag on an object.
3. How can I incorporate air resistance in my Matlab simulation?
To incorporate air resistance in your Matlab simulation, you can use the drag equation mentioned earlier. You will need to input the values for air density, velocity, drag coefficient, and area of the object in your code. This will allow your simulation to take into account the effects of air resistance on the object.
4. Can Matlab calculate drag for different shapes and objects?
Yes, Matlab can calculate drag for different shapes and objects as long as you input the correct values for air density, velocity, drag coefficient, and area. The drag coefficient and area may vary depending on the shape and size of the object, so it is important to have accurate measurements.
5. Is there a built-in function in Matlab for drag calculation?
No, there is not a specific built-in function in Matlab for drag calculation. However, with the drag equation and the necessary input values, you can easily create your own function to calculate drag in Matlab. You can also find pre-made drag calculation scripts or functions online that you can use in your code.
10K
