Dynamics of Capillary filling
In summary: He mentions the Lucas-Washburn equation, which is used to find the equilibrium height of a fluid in a capillary tube. Chetan further explains that the pressure difference, also known as Laplace pressure, is taken into account in the equation by considering the hydrostatic balance and the atmospheric pressure. The force due to pressure difference acts in the downward direction, opposing the force of gravity and surface tension at the perimeter of the meniscus. In summary, the pressure difference is included in the Lucas-Washburn equation through the hydrostatic balance and atmospheric pressure, and it acts in the downward direction opposing the force of gravity
Rishav Roy
When we write the equation for expressing the dynamics of capillary filling, why don't we include the effects of pressure difference?
What equation?
m(d^2x/dt^2)=-mg+(wetted perimeter)*surface tension-viscous forces.
This is the Lucas -Washburn equation.
Even during finding the equilibrium height (Jurin's height) at which the movement of fluid stops, we equate the gravitational forces to the surface tension forces, without considering the pressure difference. Why is that?
What pressure difference?
Sorry for the late reply.
Coming to the question, we can compute a pressure difference between the two sides of a meniscus (Laplace pressure) due to the presence of a curvature. but this computation is done when the system is static. But when we write equations describing the dynamics (Lucas-Washburn equations mentioned in my previous reply), why don't we include the force due to this pressure-difference?
What direction does this force act?
Consider a simple case of water rising up due to capillary action. Then this force due to pressure difference acts in the downward direction.
No. mg acts in the downward direction. Surface tension at the perimeter of the meniscus opposes that force.
The pressure difference actually is taken into account in the equation. The pressure in the fluid immediately below the meniscus is less than atmospheric. So the atmospheric pressure pushing down on the fluid in the bath forces fluid up the capillary. It's like sucking on a straw. If you combine the Laplace relationship with the hydrostatic balance on the fluid, the atmospheric pressures cancel, and you are left with the Lucas Washburn equation, sans the acceleration term and the viscous term.
Chet
1. What is capillary filling?
Capillary filling is the process by which a liquid is drawn into a narrow tube or capillary due to the combined effects of surface tension, adhesive and cohesive forces.
2. What factors affect the dynamics of capillary filling?
The dynamics of capillary filling are influenced by the properties of the liquid, such as surface tension and viscosity, as well as the geometry of the capillary, including its diameter and length.
3. How does gravity affect capillary filling?
Gravity plays a role in capillary filling by pulling the liquid downward, counteracting the upward capillary forces. This can lead to slower filling rates in longer, more vertical capillaries.
4. What is the relationship between capillary diameter and filling rate?
In general, larger capillary diameters result in faster filling rates due to a larger surface area available for the liquid to climb. However, there is an optimal diameter for maximum filling rate, as very large capillaries may experience a decrease in surface tension forces.
5. How does the contact angle affect capillary filling?
The contact angle, which is the angle at which the liquid meets the surface of the capillary, can significantly impact the dynamics of capillary filling. A smaller contact angle allows for stronger capillary forces and faster filling rates, while a larger contact angle can impede filling.
  • Mechanics
  • Mechanical Engineering
  • Mechanics
