Earthquake forming a volcano
In summary, it is possible for earthquakes to cause volcanoes to form, but it is not common. This can happen through changes in pressure or stress on a magma chamber or through earthquake swarms indicating movement of magma towards the surface. However, these events are rare and unpredictable, and earthquakes do not typically cause volcanoes to form on a regular basis.
caters
229
In my story about a planet called Kepler Bb(B flat like in music). It has 4 moons and orbits around a double binary star. In the 11th chapter I have an whole sequence of earthquakes in the same area that lasts for hours. Then after the earthquakes stop somebody checks the fault line and it is deep and hot. Because of this a volcano might form.
Now my humanoids have a mainly underground civilization and all those earthquakes didn't affect the homes other than it being dusty but it made all the tunnels between homes and buildings collapse.
400 people with the power of flight form groups of 4 and evacuate everyone.
As the geologist suspected a volcano formed in the place where they have been living for hundreds of years. The homes and buildings were like lava tubes.
But could it actually happen here on Earth or any other real earth-like planet that a major earthquake followed by more earthquakes in the same area could make the fault line so deep that lava starts to flow out of it and a volcanic ridge forms regardless of whether it is underwater or inland?
I know that there are volcanic earthquakes. They normally can't be felt but a seismograph can sure tell when the volcano is likely to erupt in the short term by measuring how strong the earthquake is.
I also know that occasionally a major earthquake in an area with active volcanoes will trigger the active volcanoes to erupt, even without an earthquake from the volcanoes themselves that usually happens before the eruption. An example of this is a 7.2 magnitude earthquake on the big island of Hawaii on November, 29, 1975 that was immediately followed by a short lived eruption from Kilauea.
But can earthquakes cause volcanoes to form?
It is possible for earthquakes to cause volcanoes to form, but it is not a common occurrence. In most cases, volcanoes are formed by the movement of tectonic plates or hotspots in the Earth's crust. However, there have been instances where earthquakes have triggered volcanic activity.
One way this can happen is if an earthquake causes a change in pressure or stress on a magma chamber, causing it to erupt. This is what happened in the example you mentioned on the big island of Hawaii. The earthquake caused a shift in the magma chamber, leading to an eruption.
Another way earthquakes can cause volcanoes to form is through the process of "earthquake swarms." These are clusters of small earthquakes that occur in the same area over a short period of time. These swarms can sometimes indicate that magma is moving towards the surface, which can eventually lead to a volcanic eruption.
However, it is important to note that these occurrences are rare and unpredictable. In most cases, earthquakes and volcanoes are not directly related and do not cause each other. So while it is possible for a major earthquake to trigger a volcanic eruption, it is not something that can be expected to happen on a regular basis.
1. How are volcanoes formed by earthquakes?
Volcanoes are formed when tectonic plates, which make up the Earth's crust, move and shift. When these plates collide or move apart, it can create pressure and friction that can cause earthquakes. In some cases, the movement of these plates can also create openings in the Earth's surface, allowing molten rock and ash to escape and form a volcano.
2. Can any earthquake cause a volcano to form?
No, not all earthquakes can cause a volcano to form. The majority of earthquakes are caused by tectonic plate movement, but only a small percentage of these earthquakes are strong enough to create the necessary pressure and openings for a volcano to form.
3. How long does it take for an earthquake to form a volcano?
The process of an earthquake forming a volcano can vary greatly. In some cases, it can happen almost instantly if the earthquake is strong enough to create an opening in the Earth's surface. In other cases, it can take years or even centuries for the pressure and friction from an earthquake to create a volcano.
4. Are all volcanoes formed by earthquakes?
No, not all volcanoes are formed by earthquakes. In fact, there are various other factors that can contribute to the formation of a volcano, such as hotspots, subduction zones, and rift zones. While earthquakes can play a role in some cases, they are not the sole cause of all volcanoes.
5. Can an earthquake trigger an eruption in an existing volcano?
Yes, it is possible for an earthquake to trigger an eruption in an existing volcano. The shifting and movement of tectonic plates can create changes in pressure within a volcano, which can lead to an eruption. In some cases, an eruption may be triggered by an earthquake that occurs near the volcano, but not directly underneath it.
  • Earth Sciences
