Electrical Conductivity Tensor
In summary, to find the directions in which the current is biggest and no current flows, one must find a coordinate system in which the tensor can be written as a diagonal matrix. The flow will be greatest in the direction of the eigenvector corresponding to the largest eigenvalue, and 0 in any eigenspace corresponding to a 0 eigenvalue. For a matrix with eigenvalues 0, 3, 3, the flow is greatest in all directions on the plane x+y+z=0. To find the electric field with its related components, one must use the given electric conductivity tensor.
jsmith12
If I'm given the components of an electrical conductivity tensor, how can I work out the directions in which the current is biggest and the directions in which no current flows?
Find a coordinate system in which the tensor can be written as a diagonal matrix. (Writing the original tensor as a matrix, your coordinate axes will be the eigenvectors of the original matrix, the flow along those axes the eigenvalues.) The flow will be greatest in the direction of the eigenvector corresponding to the largest eigenvalue, 0 in any eigenspace corresponding to 0 eigenvalue.
Ok thanks. But if I'm trying to work this out for the matrix
2 -1 -1
-1 2 -1
-1 -1 2
which has eigenvalues 0, 3, 3.
The 0 eigenvalue gives (1,1,1) so that's the direction of no flow, but with eigenvalue 3 you can get lots of different eigenvectors so is the flow greatest in all of those directions?
2 -1 -1
-1 2 -1
-1 -1 2
The only eigenvectors corresponding to eigenvalue 3 all satisfy x+ y+ z= 0. That means that there is a 2 dimensional "eigenspace" of covering the plane x+ y+ z= 0. The flow is the same in all directions on that plane.
if the electric conductivity tensor is given how can i find the electric field with its related components
Related to Electrical Conductivity Tensor
1. What is an electrical conductivity tensor?
The electrical conductivity tensor is a mathematical representation of how a material conducts electricity in different directions. It describes the relationship between an applied electric field and the resulting electric current in three dimensions.
2. How is the electrical conductivity tensor measured?
The electrical conductivity tensor can be measured using a technique called electrical impedance spectroscopy, which involves applying an alternating electric field to the material and measuring the resulting current. The measurements are then used to calculate the conductivity tensor components.
3. What factors affect the electrical conductivity tensor?
The electrical conductivity tensor is affected by various factors such as temperature, pressure, and the composition and structure of the material. It can also be influenced by external factors such as the presence of impurities or defects in the material.
4. What is the significance of the electrical conductivity tensor in materials science?
The electrical conductivity tensor is an important parameter in materials science as it provides crucial information about the electrical properties of a material. It is used to understand and predict the behavior of materials in electronic and electrical devices, and is also a key factor in designing and optimizing new materials for specific applications.
5. How does the electrical conductivity tensor differ from the electrical conductivity value of a material?
The electrical conductivity tensor is a more comprehensive measure of a material's electrical conductivity compared to a single conductivity value. It takes into account the directional dependence of conductivity, providing a more detailed understanding of the material's behavior. The tensor can also vary with external factors, whereas the conductivity value is typically considered constant for a given material at a specific temperature and pressure.
  • Differential Geometry
  • Electromagnetism
  • Electromagnetism
