Evaluating the Difference Quotient
To evaluate the difference quotient for f(x) = x^3 at x = 1, the expression (f(1+h) - f(1)) / h simplifies to ((1+h)^3 - 1^3) / h. The correct simplification yields h^2 + 3h + 3, which is obtained without taking the limit as h approaches 0. The initial confusion stemmed from misinterpreting the problem as requiring the derivative rather than simply simplifying the difference quotient. After recalculating with the correct approach, the solution was confirmed as correct. Understanding the distinction between evaluating the difference quotient and finding the derivative is crucial in this context.
robertmatthew
Evaluate the difference quotient of:
f(1+h)-f(1) / h
if f(x)=x3
and simplify your answer.
I took the derivative of x3 to be 3x2 and solved for when x=1 (given from the difference quotient) and got 3, but when I enter the value it's marked incorrect. Not sure what I'm doing wrong, unless I just interpreted the question the wrong way.
f(1+h)-f(1) / h
if f(x)=x3
Calculate ((1 + h)^3 - 1^3)/h and do not take the limit h \to 0.
Likes 1 person
Ah, okay. Got h^2+3h+3, entered it and it was correct. Thanks! I'm not sure why I thought it was asking for the limit, guess I'm still a little fuzzy from the summer.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
