How Were Canal Rays Explained and When?
In summary, the process of how anode rays are formed in a gas discharge anode ray tube is through the acceleration of ions present in the gas, causing collisions with gas atoms and creating positive ions. These ions are attracted to the cathode and some pass through the holes, known as the anode rays. It is believed that there are some +2 and +3 ions, but they are much less likely due to the small number of ions compared to un-ionized atoms. The explanation of canal rays was likely discovered and explained through literature, although it is unclear who first offered this explanation.
onurbeyaz
I know how the canal rays are produced. As I looked from wikipedia;
"The process by which anode rays are formed in a gas discharge anode ray tube is as follows. When the high voltage is applied to the tube, its electric field accelerates the small number of ions (electrically charged atoms) always present in the gas, created by natural processes such as radioactivity. These collide with atoms of the gas, knocking electrons off of them and creating more positive ions. These ions and electrons in turn strike more atoms, creating more positive ions in a chain reaction. The positive ions are all attracted to the negative cathode, and some pass through the holes in the cathode. These are the anode rays."
My question is, when did this explanation discovered? Did Goldstein offered this explanation when he discovered the canal rays, or somebody else did years later?
One more question: How can we be so sure that the positive ions are +1, can't it collide with one more electron on its way and become +2?
Any answer?
Even a guess is really appreciated
I would think that there are indeed some +2 ions (and possibly even +3 etc.), but only very few of them. The number of ions is probably actually very small compared to the number of un-ionized atoms, so an electron from the cathode is much more likely to hit an un-ionized atom than a +1 ion.
Likes 1 person
In addition to the difference in numbers, removing a second electron often takes much more energy than removing the first one (because you have to remove an electron from an already positively charged atom).
Likes 1 person
Thanks for the answers. So if the colliding electrons energy is enough, the +1 ion can loose one more electron (even if its very unlikely). And what about the first question? When and how did the explanation of canal rays discovered?
Right. If the electron is high-energetic, then it is not an unlikely event.
I don't know, but the literature should cover that.
1. What are canal rays?
Canal rays, also known as positive rays, are positively charged particles that were discovered in the late 1800s by scientists J.J. Thomson and Eugen Goldstein. They are produced in a high-voltage cathode ray tube and travel in the opposite direction of the cathode rays.
2. How are canal rays formed?
Canal rays are formed when a high voltage is applied to a cathode ray tube filled with a gas at low pressure. The gas molecules are ionized and the positively charged ions are accelerated towards the cathode. These ions then travel through the tube and are focused into a beam by a perforated anode, creating the canal rays.
3. What is the significance of canal rays?
The discovery of canal rays was significant because it provided evidence for the existence of positively charged particles, or protons, in atoms. This was a major breakthrough in understanding the structure of atoms and led to the development of the atomic theory.
4. How are canal rays detected and measured?
Canal rays are detected and measured using a device called a cathode ray tube. The tube contains a perforated anode which focuses the rays into a beam, and a movable detector that can be used to measure the deflection of the rays by electric and magnetic fields.
5. What are some applications of canal rays?
Canal rays have been used in various applications, such as spectroscopy, mass spectrometry, and particle physics experiments. They have also been used to study the properties of gases and the behavior of charged particles in electric and magnetic fields.
  • Atomic and Condensed Matter
  • Electrical Engineering
