Earthland
- 28
[/B]
An unpolarized ruby laser operated at 0.7 μm is projected vertically into a clear sky to investigate the density of the atmosphere. A detector located 10 km from the base of the laser is used to receive the flux density scattered from the laser beam by air molecules. Assuming that the laser output has a uniform distribution of flux density F0 across the beam (i.e., I0 = F0/π sr), and neglecting the effects of multiple scattering, find the scattered flux density at 6 and 10 km received by a detector whose field of view in a plane is 0.05 rad. Use scattering cross section σs = 1.6*10-27 cm2
Answer given:
F≅F0l*1.37*10-11 (at 10 km)
Scattered flux density is calculated as I*ΔΩ.
I = (I0/r2 )*σs*P(θ)/4π
[/B]
Let the field of view in a plane be Δ=0.05 rad.
Then ΔΩ should be ΔΩ=πΔ2/4
P(θ) = 3/4 * (1+cos2(θ))=3/4
However, if I try to calculate
(F0/π*r2 )*σs*(3/16π)*πΔ2/4
where r = 10km, the answer would be something like ~10-40
