How Does a Glass Fibre Flywheel Store Kinetic Energy in Buses?
In summary: You should have a formula for the number of radians in a revolution. You should also be able to convert minutes to seconds. You should also be able to look up the formula for angular velocity. You have all the information you need to answer this question.In summary, a flywheel made of glass fibre has been developed by BP to store the kinetic energy of buses when they come to a bus stop. The maximum energy stored in the flywheel is equivalent to the energy lost by a 16,000 kg bus braking from 48 km when it comes to rest. The bulk of the flywheel’s mass is in its rim which moves at 1300 km when the flywheel rotates at the maximum angular velocity of
Katy96
32
A flywheel made of glass fibre has been developed by BP to store the kinetic energy of buses when they come to a bus stop. The maximum energy stored in the flywheel is equivalent to the energy lost by a 16,000 kg bus braking from 48 km when it comes to rest. The bulk of the flywheel’s mass is in its rim which moves at 1300 km when the flywheel rotates at the maximum angular velocity of 16,000 rev . After a typical stop of two minutes during which time the flywheel slows down, four fifths of its energy is still available to accelerate the vehicle.
From this data show that the flywheel has the following properties:
  1. Maximum kinetic energy = 1.42 MJ (2 marks)
  2. Moment of Inertia = 1.01 kg (3 marks)
  3. Radius = 0.215 m (2 marks)
  4. Minimum mass = 21.9 kg (3 marks)(Each section must be answered in the order given. You may not assume data from the following sections).e) Determine also the
  5. Determine also the mean frictional torque causing the slowing down in the two minute stop. (6 marks)
not really sure!
I can't figure out how to do this as I don't know how to do it In this order?
Why don't you start with question 1? It's asking about the total KE of the flywheel. Where does this KE come from?
I tried using
and then I didn't know which other equation I could use but I don't know the radius or anything
Katy96 said:
I tried using View attachment 86949and then I didn't know which other equation I could use but I don't know the radius or anything
Where does the KE come from?
The kinetic energy of an object is the energy it possesses because of its motion?
Okay, I'll get you started. The energy comes from the bus. It tells you that in the question.
well yes I understand that part, I just don't understand how I use what I've been given to work it out as I am used to using
Katy96 said:
well yes I understand that part, I just don't understand how I use what I've been given to work it out as I am used to using View attachment 86951
How else could you work out the energy of the flywheel? Hint: think about the energy of the bus.
E = ½mv2?
Katy96 said:
E = ½mv2?
If you mean the energy of the flywheel is equal to the energy of the bus, and you're given the mass and velocity of the bus, then yes!
yeah that's what I meant, so I use the mass of the bus and the speed from which it is braking from?
Yes, that's what the question implies.
but if I do that I get that E=18432000?
What units are you using? I assume the speed is 48 km/h? What if the speed of the bus was given in mph (miles per hour)? Or cm/s?
yes its 48km/h so what I did was (0.5)(16000)(48)^2
So, why is that wrong? Note that 48 km/h is about 30 mph. So, why not (0.5)(16000)(30)^2?
the answer, Maximum kinetic energy = 1.42 MJ, is given in the question, when 30mph is used you get 7200000 which is also the wrong answer
So, if you take the speed in different units, you get different numerical answers. There is only one set of units in the SI:
Kilograms, Metres, Seconds and Joules
You must use mass in kilograms and speed in metres per second to get KE in Joules.
so how do I change 48km/h into m/s? never mind I got it now!
Are you really saying that if a bus is going at 48 km/h, you don't know how far it travels each second?
ive done it, and done part a, I am just getting confused on which equations I need to use for which parts.
so in part b I know I need to use
Katy96 said:
so in part b I know I need to use View attachment 86958
Yes, you've got the KE now and you're given ##\omega## (although you need to watch the units again), so you should be able to calculate ##I##.
which is ω?
Katy96 said:
which is ω?
Read the question.
PeroK said:
Read the question.
I have, I can't figure it out and by that I mean how do I change it to something I can use units wise
##\omega## is "angular velocity", which must be used in radians per second. The question gives you it, however, in revolutions per something. Just as an aside, you seem to have truncated most of the units when quoting the question.
yes its given in revolutions per min, and I am unsure of how to change it from revolutions per min to radians per second once I do that I know how to do part b)
How many radians are in a revolution?
2Pi/60?
  • #31
Katy96 said:
2Pi/60?
A poor guess. It's ##2\pi##. You could always have googled that!
  • #32
Is editing a response as you type it a lost skill?
I see this so often it's ridiculous !
  • #33
okay well do I just divide by 2pi? because I thought you would do 16000X2pi/60
  • #34
I see what you did. There are ##2\pi## radians in a revolution, so yes it's ##2\pi /60## to convert from revs per minute to radians per second.
  • #35
when I did that I got the right answer so in part c do I use vmax=rωmax or do I use I=0.606mr2
9K
14K
