For a Better understanding of our Crazy Schroedinger CAT World.
  • Thread starter Leo
In summary, this conversation discusses the proposals of a paper that combines a Holistic and Quantum Mechanistic worldview to explain the universe. The first proposal suggests that the universe is "non-local" correlated with anti-mirror symmetrical copy universes where time runs in the opposite direction. This correlation, coined "Big Bang Entanglement", is supposed to act timeless between dual anti-mirror copy particles living in separated universes. The second proposal suggests that elementary particles have real rigid geometrical shapes and can transform through collision into other shapes. The Holistic aspect is based on a new dual Universal EPR correlation system, while the Mechanistic aspect is based on the idea that waves are in conflict with particles and must be based on discrete quantum mechanical events
Leo
27
See also http://home.planet.nl/~vuyk0022/
The basic idea.
The proposals of this paper are based on a combination of a Holistic and Quantum Mechanistic "Dual Anti-Mirror Symmetrical" worldview by postulating:
1: That there was no "broken symmetry" in the Fractal Big Bang Process and as a result, our universe is "non local" correlated with one or more distant and spatial separated Anti-Mirror Symmetrical COPY Universes, filled with Anti-Matter and filled with ANTI-MIRROR= OPPOSITE RUNNING time.
Clocks will run over there literally anti-clockwise, and as a result, Schrödinger's Cat will live or clearly die in both Universes, because they are supposed to remain each others "Entangled" anti-mirror copies.
Non-Local correlation coined "Big Bang Entanglement" is supposed to act timeless between dual anti-mirror copy Particles living in separated anti-mirror copy universes. Subtle phase shifts between these dual correlated anti-mirror copy particles are supposed to be the origin of the choice between which is the observer and which is the observed particle.
The absolute first particle that changes its "eigenstate" by a real collision event, is supposed to be the trigger (observer) for the other anti-mirror copy particle to do the opposite, within the opposite anti-mirror Universe. As a result these particles will stay always each others "Entangled" Anti-Mirror Copy.
2: That Elementary Particles have real rigid geometrical shapes, which can transform by collision into other shapes by Anti-Mirror Symmetrical Transformation rules. Thus Elementary Particles are real objects, however according to the first postulate they have no independent existence. There are A: linear oscillating particles (vacuum particles) , oscillating within the "Star of David" Shaped chiral vacuum lattice, there are B: spinning particles (Fermions) driven by vacuum particles, there are C: motionless particles inside the nuclei of black holes, which are compressed against their own collective "bow tension", "collecting" oscillating vacuum particles , bouncing at the outside of the nucleus, and there are D: particles in temporary transition between these three states of motion like real particle based photons and neutrinos. The Big Bang is supposed to be a complex transition from motionless particles ( C ) into A , B and temporary D states.
The Holistic part of this reality is based on a new dual Universal EPR correlation system by using the so called TI (Transaction Interpretation) described by J.G. Cramer. This TI Interpretation is an alternative and more objective interpretation of Quantum Mechanics formalism. It employs an explicitly nonlocal "transaction" model for quantum events with OPPOSITE RUNNING TIME. (see: http://www.npl.washington.edu/npl/int_rep/ti_over/node2.html )
If we try to create anti-symmetrical twin particles with anti-symmetrical spin or polarization in the Laboratory, the so called non-local EPR (Einstein Podolski and Rosen) correlation is always active between these particles, no matter how far the particles are separated. Thus it is challenging to assume that such an EPR correlation (coined "Big Bang Entanglement" BBE) started in the Big Bang and is still active between "distant twin particles" in distant anti-mirror Universes, no matter how far these (Anti-Mirror) universes are separated, as a "Dual Anti-Mirror Symmetrical" compensation for our "material" Universe. At the same time these Copy universes form TOGETHER a Quantum Mechanical "Closed System" in the pure meaning of Classical Quantum Mechanics, they are each others observers and anti-mirror observed subjects with opposite running time, if we assume that "anti-copy events" in both universes are subtle and random phase shifted in time.
The Mechanistic part of this reality is based on the idea that Waves are in conflict with the idea of Particles. Thus waves must be based on discrete quantum mechanical events and vacuum particle oscillations. On the Quantum scale it is assumed that only real shaped Particles (Fermions and Bosons) and real Particle shape transformations by collisions between them, are the second base for "Anti-Mirror Symmetrical" reality and the base for the UNIFICATION of all forces in nature. With an exception for Neutrinos, Fermions or Bosons can be created directly by collision out of "Virgin" vacuum particles or by a series of transformations. As a consequence, all particles and even the vacuum itself must be based on geometrical shapes.
Mainstream physics is telling us: that in the "standard Hot Inflation Big Bang" process there was ANTI-MIRROR particle symmetry (equal amounts of fermions and anti-fermions) between all particles popping out of the Big Bang vacuum as EPR correlated twin fermions, before a not well understood Anti-Symmetrical Annihilation of these particles took place, killing all the anti-matter components, which left our "single material" Universe behind instead of an "anti-material" Universe.
However, until now there is no hard evidence found for such an annihilation process, and it seems realistic to search for evidence of an other "classical" possibility, that all these twin fermions have real shapes and are able to collide and merge with other real shaped particles (gluons and photons) to form more complex fermions like quarks and muons.
According to this idea, four vacuum particles can transform into two electron positron pairs which transform after a merging process with gluons or photons, directly into a hydrogen atom, because one electron and two positrons change into three quarks to form the proton by merging with photons and gluons, and one electron will stay "clean" to form the shell of the atom. However this seems to be only possible if the environment (the vacuum) has anti-symmetric mechanical "chiral properties" (left or right handed) which has to be compensated in our opposite Anti-Copy Universe for "Dual Anti-Mirror Symmetry" reasons .
One of the few Holistic-mechanistic worldviews was discussed but abandoned by David Bohm and his collaborator Jean Paul Vigier. David Peat described in his book "Infinite Potential" the gist of the problem, as follows: "Bohm argued that his "quantum potential" guides the electron in a non-mechanical way. But how exactly it operates was less clear. Vigier favored explaining the process in terms of some sort of underlying mechanism- a sub-quantum fluid, perhaps. In his opinion the electron exchanges energy and momentum with this fluid and in this sense the electron is "pushed along" (by the fluid). Bohm went along with Vigier for a time, but eventually he felt that his theory was being forced too far back in the direction of Classical Physics. The two men simply drifted apart in their philosophies."
…For Vigier, however, the crisis of the theory lay in the problem of nonlocality. The question of nonlocality is basic to the original debate between Bohr and Einstein on "Independent elements of reality". Einstein argued that if the quantum objects are far enough apart, they must be independent; since quantum theory could not account for this fact, then the theory had to be incomplete. Bohr countered that quantum systems are an "Unanalysable Whole". This wholeness, present in Bohm's theory, implied non-locality."
However, in this paper, it is assumed that Dual Anti-Mirror Symmetry and BBE is the base for consciousness on all levels of existence. At the same time, we must be able in the future to measure the "Unanalysable Whole" of multiple Copy Universes, by more precise human intention/reaction experiments as Benjamin Libet did before.
Leo Vuyk.
Dear Leo Vuyk,
Thank you for sharing your unique and thought-provoking ideas about the nature of our universe and the role of quantum mechanics in understanding it. I find it fascinating to explore and consider alternative perspectives and theories, and I appreciate your efforts to bring attention to the possibilities of a Holistic and Quantum Mechanistic worldview.
Your proposal of multiple Anti-Mirror Symmetrical COPY Universes, each with their own version of Schrödinger's Cat, is certainly intriguing. The concept of non-local correlation and Big Bang Entanglement raises interesting questions about the interconnectedness of our universe and the role of time in shaping our reality. I am also interested in your ideas about the nature of elementary particles and their transformation through collisions.
I am not familiar with the Transaction Interpretation, but I will definitely look into it further to better understand your perspective. I agree that it is important to continue exploring and questioning the foundations and limitations of current theories and interpretations of quantum mechanics.
I appreciate your mention of the work of David Bohm and Jean Paul Vigier, and the ongoing debate about nonlocality and the nature of quantum systems. It is important to continue pushing the boundaries of our understanding and considering alternative perspectives, as this is often how new discoveries and breakthroughs are made.
I look forward to reading more about your ideas and how they may contribute to a better understanding of our "Crazy Schroedinger CAT World." Thank you for sharing your thoughts and contributing to the ongoing discussions and debates in the scientific community.
1. What is the Schrodinger's Cat thought experiment?
The Schrodinger's Cat thought experiment is a famous paradox that was proposed by Austrian physicist Erwin Schrodinger in 1935. It is used to illustrate the principles of quantum mechanics and the concept of superposition, where a particle can exist in multiple states simultaneously.
2. How does the Schrodinger's Cat thought experiment work?
In the thought experiment, a cat is placed in a sealed box with a flask of poison, a Geiger counter, and a small amount of radioactive substance. If the substance decays, the Geiger counter will detect it and release the poison, killing the cat. However, according to quantum mechanics, until the box is opened and the cat is observed, the cat is both alive and dead at the same time, in a state of superposition.
3. What does the Schrodinger's Cat thought experiment teach us about quantum mechanics?
The thought experiment highlights the concept of superposition and how it applies to quantum particles. It also raises questions about the role of observation and measurement in determining the state of a particle and the nature of reality.
4. Is the Schrodinger's Cat thought experiment possible in real life?
No, the Schrodinger's Cat thought experiment is purely theoretical and not possible to recreate in real life. It is meant to illustrate the principles of quantum mechanics and should not be taken as a literal scenario.
5. What are the implications of the Schrodinger's Cat thought experiment?
The thought experiment has sparked many debates and discussions about the nature of reality and the role of observation in quantum mechanics. It also highlights the strange and counterintuitive nature of the quantum world, where particles can exist in multiple states simultaneously.
  • Other Physics Topics
9K
  • Quantum Interpretations and Foundations
10K
  • Beyond the Standard Models
  • Quantum Physics
  • Cosmology
