[Fortran] Implcit type problem
In summary: In...: .text:0x408bac8: call Newton/usr/lib/gcc/x86_64-redhat-linux/4.4.7/libgfortranbegin.a(fmain.o): In...: .text:0x408bad0: movl $0x0,(%rsp)/usr/lib/gcc/
Bashkir
31
I'm writing a subroutine for solving Newton's method for the root of a function and I am coming across an interesting problem. This is the start of my code, where it is says the error is occurring
SUBROUTINE Newton(f, x1, x2, dx, aroot, error)
IMPLICIT NONE
! Declare Arguments
REAL, EXTERNAL :: f
REAL, INTENT(IN) :: x1
REAL, INTENT(IN) :: X2
REAL, INTENT(IN) :: dx
REAL, INTENT(OUT) : aroot
INTEGER, INTENT(OUT) :: error
! Declare parameter:
REAL, PARAMETER :: epsilon = 1.0E-5 ! Convergence criterion
!Declare local variables:
LOGICAL :: l_value_a ! True if f(xa) > 0
LOGICAL :: l_value_b ! True if f(xb) > 0
LOGICAL :: l_value_m ! True if f(xm) > 0
INTEGER :: i ! Index variable
INTEGER :: n ! Number of iterations
REAL :: value_a, value_b, value_m ! f(xa), f(xb), f(xm)
REAL :: xa, xb, xm ! Start, middle, end of interval
Now, when I try to compile the whole routine it gives me this error
Error: Invalid character in name at (1)
Newton.f90:1.38:
Error: Symbol 'aroot' at (1) has no IMPLICIT type
I'm really not sure where I am going wrong here. Any help would be appreciated. Thank you!
Technology news on Phys.org
IMPLICIT NONE
! Declare Arguments
REAL, EXTERNAL :: f
Newton.f90:1.38:
Do you notice any difference between the line that's colored and the rest?
REAL, EXTERNAL :: f
Even with a double colon it still gives me the same error.
It also looks like you have 'x2' in the subroutine argument list and 'X2' in the declaration list.
So Fortran is case-sensitive now? :eek:
The same error? The two errors in the OP specifically cited aroot.
Newton.f90:1.38:
If the new errors are actually different, please show them.
Okay, haha. Adding the double colon did change things.
/usr/lib/gcc/x86_64-redhat-linux/4.4.7/libgfortranbegin.a(fmain.o): In function `main':
(.text+0x26): undefined reference to `MAIN__'
collect2: ld returned 1 exit status
Is what I am getting with a double colon.
Bashkir said:
Okay, haha. Adding the double colon did change things./usr/lib/gcc/x86_64-redhat-linux/4.4.7/libgfortranbegin.a(fmain.o): In function `main':
Do you have a function named main? Please post all of your code.
This doesn't seem to be a syntax error that the compiler catches. I think that it might be a linker error. Have you been able to run any of your Fortran code? If not, you might not have things set up correctly.
it looks like an attempt to produce a final executable out of a file that only contains a subroutine...you need a main program where to call the sub from.
Code:
program mymain
contains
    subroutine Newton
    end subroutine Newton
end program mymain
Or, if you already have a main somewhere else, then, you are NOT suppose to compile this given file into an executable, just into *.o file, first and then you link all your *.o into an *.exe or no extension whatsoever a-la-linux
Gsal -- I am trying to compile it into a -o.
The Full code, is this.
SUBROUTINE Newton ( f, x1, x2, dx, aroot, error )
IMPLICIT NONE
! Declare Arguments
REAL, EXTERNAL :: f
REAL, INTENT(IN) :: x2
REAL, INTENT(OUT) :: aroot
! Declare local variables:
INTEGER :: i
INTEGER :: n
REAL :: xa, xb, xm
! First check to make sure that the interval to search is valid.
error_chk: IF ( x1 > x2 ) THEN
error = 1
aroot = 0
ELSE
! Initializing error flag to 2, since no root found yet
error = 2
aroot = 0
! Get number of steps to search over for sign change
n = NINT( (x2-x1) / dx + 1. )
! Now search for a zero crossing. Get starting value
! at first step.
xa = x1
value_a = f(xa)
l_value_a = value_a > 0
! Search for a sign change between x1 and x2
outer: DO i = 1, n
! Get value at end of interval
xb = MIN( x1 + REAL(i-1) * dx, x2 )
value_b = f(xb)
l_value_b = value_b > 0.
! Is there a sign change in this interval?
sign_change: IF ( l_value_a .NEQV. l_value_b ) THEN
! There was a sign change in the interval. The
! root is somewhere between xa and xb. Process
! it in a WHILE loop.
inner: DO
! Get value at midpoint,
xm = (xa + xb) / 2.
value_m = f(xm)
l_value_m = value_m > 0.
! Test for convergence
IF (ABS((xb-xa) / xm) <= epsilon) THEN
aroot = xm
error = 0
EXIT outer
ELSE IF (l_value_a .EQV. l_value_m) THEN
! The sign change was in the second half.
xa = xm
value_a = value_m
l_value_a = l_value_m
ELSE
! The sign change was in the first half.
xb = xm
value_b = value_m
l_value_b = l_value_m
END IF
END DO inner
END IF sign_change
! We are still searching for a sign change here
! Set new starting point for interval.
xa = xb
value_a = value_b
l_value_a = l_value_b
END DO outer
END IF error_chk
END SUBROUTINE Newton
If you're trying to compile this directly into an executable program, you need a "main program" in this file, as gsal said.
If you want to compile it to a .o file that will be linked later to a separately-compiled main program, then (since you're apparently using Linux or something Unix-like), you need to use the -c compilation flag, something like
gfortran Newton.f -o Newton.o -c
or maybe simply
gfortran Newton.f -c
What is an implicit type problem in Fortran?
An implicit type problem in Fortran refers to a situation where the compiler automatically assigns a data type to a variable without the programmer explicitly specifying it. This can lead to unexpected results or errors in the program.
How does an implicit type problem occur in Fortran?
An implicit type problem can occur in Fortran when a variable is declared without explicitly specifying its data type, or when the data type specified is different from the one intended. It can also occur when mixing different data types in an operation.
What are the consequences of an implicit type problem in Fortran?
The consequences of an implicit type problem in Fortran can vary depending on the situation. It can result in incorrect calculations or unexpected behavior of the program. It can also lead to difficult-to-detect errors, making it challenging to debug the code.
How can an implicit type problem be prevented in Fortran?
To prevent implicit type problems in Fortran, it is essential to always explicitly declare the data type of each variable. It is also recommended to use the "implicit none" statement at the beginning of the program, which will force the programmer to explicitly declare all variables.
How can implicit type problems be resolved in Fortran?
To resolve an implicit type problem in Fortran, the programmer needs to identify where the error is occurring and then explicitly declare the data type for the variables involved. It may also require fixing any incorrect data type conversions or operations.
14K
