How Deep Does the Acrylic Bottom Appear Under Water?
In summary: The distance from thereal object to this virtual image is the apparent depth of the object as seen from abovethe water surface.In summary, to determine the apparent depth of the bottom surface of the acrylic block when viewed from above the water surface, one can use Snell's law and a ray diagram. By extending the refracted rays back, the distance from the real object to the virtual image will give the apparent depth of the object as seen from above. This can be calculated using the refractive indices of the water and acrylic.
feliperrr
A container with a layer of water (n=1.33) of 5 cm thick is over a block of acrylic (n=1.5) of 3 cm thick. An observer watches (perpendicularly from above) the lowest surface of the acrylic. What distance does it (the bottom surface) seems to be from the top of the water?
(n1/p) - (n2/q) = (n1-n2)/r
(n1/p) - (n2/q) = 0
q = n2p/n1
(n1/p) - (n2/q) = 0
q = n2p/n1
i think you can use the relation ship between real depth of an abject and apparent depth of the same object related to ratio of the refractive indices of the medium.
as the bottom is being viewed vertically so one can take paraxial rays close to the vertical and extend the emergent ray below to find the apparent position of the image.
what will be depth of the acrylic slab when viewed from water?
and what will be the depth of this image when viewed from above -the water surface?
I would rather suggest to use Snell's law and a ray diagram :wink:
Draw such a diagram with rays from a point on the bottom surface of the block.
These rays are refracted when they pass from the block into the water (ignore the glass)
and again as they exit the water surface. These rays will then indicate where the virtual
image of the point is located if you extend the rays backwards.
Related to How Deep Does the Acrylic Bottom Appear Under Water?
1. What is geometrical optics?
Geometrical optics is a branch of physics that deals with the study of light as it behaves in a purely geometrical manner. It focuses on the behavior of light rays and their interactions with various materials, without taking into account the wave nature of light.
2. What are the basic principles of geometrical optics?
The basic principles of geometrical optics include the laws of reflection and refraction, which describe how light rays behave when they encounter a surface or boundary between two different materials. It also includes the principle of least time, which states that light will always travel through the path that takes the least amount of time.
3. How is geometrical optics used in everyday life?
Geometrical optics is used in many everyday applications, such as mirrors, lenses, glasses, and cameras. It is also used in the design and construction of optical instruments, such as telescopes, microscopes, and binoculars. Additionally, geometrical optics is used in the study of human vision and the correction of vision problems.
4. What is the difference between geometrical optics and physical optics?
Geometrical optics is a simplified model that only considers the behavior of light as rays, while physical optics takes into account the wave nature of light. Physical optics is used to explain phenomena such as interference, diffraction, and polarization, which cannot be explained by geometrical optics.
5. How is geometrical optics related to other branches of physics?
Geometrical optics is closely related to other branches of physics, such as electromagnetism, thermodynamics, and quantum mechanics. It is also used in the study of topics such as light-matter interactions, optical properties of materials, and the behavior of light in different environments.
