Glide Ratio & Scale: Designing Gliders for Maximum Air Time/Distance
  • Thread starter Thread starter herpamad
    Ratio Scale
The discussion focuses on designing gliders with optimal lift-to-drag (L/D) ratios for maximum airtime and distance. It highlights the challenge of identifying the most efficient full-size and R/C gliders. Key considerations include the importance of flying at the correct speed for achieving the best glide ratio and the role of angle of attack in aerodynamic performance. The conversation also questions whether adapting a glider for low-power, long-distance flight is more effective than building a new aircraft from scratch. Overall, the insights aim to enhance understanding of aerodynamics in the context of glider design.
herpamad
Hi
I am looking into the design of gliders with good L/D / Glide Ratio.
It seems hard to find what is the most efficient full size glider, and the same goes to a scale r/c type one too.
So any ideas?
If i was to start from scratch, what should i be looking at to get the best l/d ratio possible?
The AIM is to get the most airtime and/or distance.
I read in a book that speed has little effect on the L/D ratio, is this true? If so, is this only true down to a certain speed, ie, stall speed?
Project needs to address to if the aircraft can be used with a powerplant.
Is the use of a glider for adaption to a low power, and long distance aircraft better than building an aircraft from scratch for this purpose?
My area of study is Mech Eng, but I want to get into Aero Engineering after graduation, and i have an interest in fluids and aviation in general, thus having an Aero themed project to try get some knowledge about Aero Engineering.
Flying gliders but not R/C model I'm not sure what you ask. A modern glider has a glide ratio around 40-50 with the airspeed for maximum glide a bit above the speed for minimum sink rate, as calculated as the "tangent" from the glide polar [1]. The glide ratio do vary with speed, enough so that flying with the "correct" speed is significant in competition flights [2] and you would usually also correct for wind speed so that you fly a bit faster in head wind and a bit slower in tail wind.
I assume the performance of a R/C glider somehow can be transformed from the performance figures of a real size glider using the "standard" scale laws in aerodynamics, but I suspect "heuristic" knowledge about build and flying R/C models is far more important than general theoretical knowledge about aerodynamics.[1] http://en.wikipedia.org/wiki/Polar_curve_(aviation)
[2] http://en.wikipedia.org/wiki/Speed_to_fly
herpamad said:
Hi
So any ideas?
Any aerodynamic behavior of a vehicle is a function of its angle of attack and sideslip. Airspeed does not dictate best L/D ratio, angle of attack does.
All i was wondering, thanks.
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
