Pranav_Indian
- 4
- 1
why can't we go for harvesting hydropower from the pipelines, eventhough the flow is not continuous we can generate and store it,,, and can use it for small devices..
Welcome to the PF.Pranav_Indian said:why can't we go for harvesting hydropower from the pipelines, eventhough the flow is not continuous we can generate and store it,,, and can use it for small devices..
its the potential energy stored in the tank...berkeman said:Welcome to the PF.
And where would that extra energy come from that you are extracting along the way in the pipelines...?
Potential energy is only used for long distance slow liquid transfer (like water aqueducts transferring water long distances). Most pipelines are pumped, so you would need to add extra pumping power at the source to give you any excess energy to extract along the way...Pranav_Indian said:its the potential energy stored in the tank...
potential energy is not only used for long distance slow fluid transfer, what in the case of a dam.. there the fluid at rest have a potential energy and that one is routed to harnish electricity... but there we get a continuous high velocity jet of stream due to the high water head, but in case of a tank head is low, so we will go for small application devicesberkeman said:Potential energy is only used for long distance slow liquid transfer (like water aqueducts transferring water long distances). Most pipelines are pumped, so you would need to add extra pumping power at the source to give you any excess energy to extract along the way...
http://www.prohim.com.tr/files/cache/431b5a2c9e79b65a44a1957295942aec_f857.jpg
After the dam water has fallen down through the hydroelectric generators, it has lost most its potential energy. The water flow out of hydroelectric dam facilities has very little energy left, and just flows slowly down the river, or is pumped to local water utilities.Pranav_Indian said:potential energy is not only used for long distance slow fluid transfer, what in the case of a dam.. there the fluid at rest have a potential energy and that one is routed to harnish electricity... but there we get a continuous high velocity jet of stream due to the high water head, but in case of a tank head is low, so we will go for small application devices
ok sir... thank you for your wordz...berkeman said:After the dam water has fallen down through the hydroelectric generators, it has lost most its potential energy. The water flow out of hyddroelectric dam facilities has very little energy left, and just flows slowly down the river, or is pumped to local water utilities.
There is some energy that can be harvested from tides, and we've had a few threads about that here at the PF. You can find more threads about energy harvesting by doing a PF search.
You can. [ref]Pranav_Indian said:why can't we go for harvesting hydropower from the pipelines,
"small devices"?eventhough the flow is not continuous we can generate and store it,,, and can use it for small devices..
Harvesting energy from pipelines involves using devices called thermoelectric generators (TEGs) to convert the thermal energy from the hot oil or gas inside the pipeline into electricity. The TEGs use temperature differences between the hot fluid and the cooler environment to generate electricity through the Seebeck effect.
Harvesting energy from pipelines can provide a sustainable and renewable source of electricity without the need for additional infrastructure. It can also reduce the carbon footprint and operating costs of the pipeline by utilizing the excess heat that would otherwise be wasted.
One of the main challenges of harvesting energy from pipelines is the variability in temperature and flow rate of the fluid inside the pipeline, which can affect the efficiency of the TEGs. Additionally, the initial cost of implementing TEGs can be high, and regular maintenance is required to ensure optimal performance.
Most types of pipelines that transport hot fluids, such as oil, gas, or steam, are suitable for energy harvesting. However, the size and flow rate of the pipeline, as well as the temperature difference between the fluid and the environment, can affect the effectiveness of energy harvesting.
Yes, harvesting energy from pipelines is considered a sustainable practice as it utilizes a renewable energy source and does not produce any emissions. It also helps to reduce the reliance on non-renewable energy sources and contributes to the overall goal of reducing carbon emissions.
