How Do You Calculate Engine Power for Semi Trucks in Various Conditions?
In summary: Can you elaborate a bit more on the headwind calculation?In this case, you would use:Headwind in meters per second:10 * Speed of the truck in meters per second (22,22)This would result in a headwind of 22,22 meters per second.Can you give an example of a slope or level road that you would use for the comparison?I would use a level road.Can you give an example of a truck that you are calculating the power for?I don't have a specific truck in mind, but I would use a truck that is similar to the one I'm using for the calculation.
WumTrudo
Summary: Calculating engine power required for semi trucks under different circumstances.
Hello everyone,
I would like to ask you for help if that is allowed.
For a current project I need to calculate engine power needed in watts under different circumstances.
This is something that I will have do more often, so I would like to make this into an excell sheet where I can simply input the prevailing conditions, and have it calculate the right value(s).
However, I underestimated the complexity of the formula due to all the different variables.
Can someone help me get to the right formula?
The value(s) are as follows:
Calculate the engine power needed for the following semi trucks in the described situations:
Semi Truck data:
Dimensions: L: 14m W: 2,55m H: 2,74
Front face of truck in m2: 7m2
Gross train weight: 40.000 kg
Overall drive train efficiency: 95%
CW value air resistance: 0,6
Situation 1:
Engine power (in kW), needed for the truck above to:
Drive up a slope of 3% with 80k/ph, while experiencing a headwind of 10kph.
Road Condition: Good asphalt with a rolling friction coefficient of 0.007.
Situation 2:
Drive up a slope of 3% with 80k/ph, while experiencing a headwind of 15kph.
Road Condition: Sandy roads with a rolling friction coefficient of 0.2.
So far I have come up with for situation 1:
Formula for rolling resistance in Newtons:
9.81 * friction coefficient * vehicle weight in kilo’s * cos (angle of slope in degrees)
9.81 * 0.007 * 40000 * cos 1.72
= 2746 N
Formula for slope resistance in Newtons:
9.81 * vehicle weight in kilo’s * sin 1.72
9.81 * 40000 * sin 1.72
= 11778 N
Formula for air resistance in Newtons:
0.6 * 0.6 * 7 * 22,22^2
= 1244 N
Total resistance in Newton:
2746 N+ 11778 N + 1244 N = 15768 N
Formula for Required power without taking into account the driveline efficiency:
Total resistance * velocity in meters per second
15768 * 22,22 = 350364 watts (350,364kW)
Formula for Required power taking into account the driveline efficiency:
Power Required / driveline efficiency
350,364 / 0,95 = 368,804kW
This is how far I’ve come on my own, and I know I haven’t taken into account the headwind yet. I would like it if anyone could help me by looking over the calculations so far, and help me perfect them.
Kind Regards,
Wim
Is this homework? If so, we can move it to the homework forum.
Total resistance is the sum of rolling resistance on a level road plus slope resistance plus air drag. Those three are calculated separately, then added at the end. Also, be aware of significant digits. You do not get six digits of accuracy when starting with one digit inputs.
Likes CalcNerd and WumTrudo
I thought I posted it in homework. I changed the prefix to automotive, did I go wrong there?
You posted it in the ME forum. I'll move it to the schoolwork forums for you now. :smile:
Likes WumTrudo
Thanks!
WumTrudo said:
Semi Truck data:
Situation 1:
Road Condition: Good asphalt with a rolling friction coefficient of 0.007.Formula for air resistance in Newtons:
= 1244 N
Can you elaborate on the drag formula you used a bit more?
Typically, ##F_d =C \rho A v^2##
##F_d =\frac{1}{2} C \rho A v^2## (Forgot the factor of a half- now the calcs makes sense)
##C## is the drag coefficient
##\rho## is the density of the air
##A## is the cross sectional area
## v ## is the velocity of the air as seen from the perspective of the truck.
Likes WumTrudo
In this case i’ve used:
drag coefficient (0,6) * Density of the air (0,6) * the cross section of the sectional area in m2 (7) * Speed of the truck in meters per second (22,22)^2
Likes erobz
Actually, you used ##\frac{1}{2}\rho C_DAv^2## where ##\rho = 1.2\ kg/m^3##.
As for your calculations, everything looks OK to me.
What you may want to explore now is if your truck has enough traction to handle that much force. If the driven tires cannot produce enough friction force, the tires will just spin out and the truck won't move.
All you have to do to answer the initial question is account for the wind velocity ##w##.
Likes WumTrudo
1. How do I calculate engine power?
To calculate engine power, you will need to know the torque and rotational speed of the engine. The formula for engine power is: Power = (Torque * Rotational Speed) / 5252. Make sure to use consistent units for torque (lb-ft or Nm) and rotational speed (RPM or rad/s).
2. What is the difference between horsepower and torque?
Horsepower is a measure of power, which is the rate at which work is done. Torque, on the other hand, is a measure of rotational force. In other words, horsepower is a measure of how fast an engine can do work, while torque is a measure of the engine's ability to turn.
3. How does engine size affect power?
Generally, a larger engine size will result in more power. This is because a larger engine can accommodate more fuel and air, allowing for a larger explosion and more power. However, other factors such as engine design and efficiency also play a role in determining engine power.
4. Can engine power be increased?
Yes, engine power can be increased through various methods such as tuning, adding forced induction (turbocharging or supercharging), and upgrading engine components. However, it is important to note that increasing engine power may also put additional strain on the engine and can affect its longevity.
5. How does altitude affect engine power?
As altitude increases, the air becomes less dense, resulting in less oxygen available for combustion. This can lead to a decrease in engine power, as the engine is not able to produce as much power with less oxygen. This is why engines may feel less powerful at higher altitudes.
  • Mechanical Engineering
11K
