eqm
- 7
Determine the maximum velocity attainable by a vehicle with the following conditions:
- RWD
- 6% grade
- Weight = 20 kN
- CG is 1.25 m behind front axle and 0.5 m above ground level.
- Wheel base is 2.8 m.
- Effective rolling radius of wheel = 30 cm
- Coefficient of aerodynamic drag = 0.45 with frontal area 2.3m2
- ρ = 1.25 kg/m3
- Engine develops peak torque at 45 kW and 4000 rpm
- The rotating inertia of the gearbox is and engine is 0.454 kgm2
- The rotating inertia of each wheel with driveline is 1.76 kgm2
- coefficient of friction between road and tire μ = 0.8
Wr = (W l1cosθ + Rah + W h sinθ)/L
Max Tractive Effort = μ Wr
Ra = 1/2 ρ V2 A CD
To solve this problem, I was going to first determine if the wheel torque is limited by the vehicle motor or by road adhesion, then find the maximum velocity using the limiting torque. I can get motor torque but am stuck at this point as I am not given a gear ratio to be able to convert motor torque to wheel torque.
TM = 30 P nrpm / π = 107.43 N/m
I know how to solve for everything else, its really just the the conversion to wheel torque that I'm stuck at (unless I'm approaching this problem entirely wrong).
