Help with finding normal modes of a bar swinging on a string
BiotFartLaw
A bar with mass m and length l is attached at one end to a string (also length l) and is swinging back and forth. Find the normal modes of oscillation.
L=T-U, and the Lagrange-euler equation, I=(1/12)ml^2
So my idea is this. Use the two angles \theta (angle of string from the vertical) and \phi (angle of the bar from the vertical) as the generalized coordinates and set up a Lagrangian to get two (probably coupled) differential equations. THen I'm guessing two different eigenfrequencies will pop out when I solve them.
My problem is that I'm not sure what the (translational) kinetic energy is. (The rotational would just be I*ω^2 and this ω^2 would, in the end, give me the two frequencies [?]) I've tried finding \dot{x} and dot{y} using sines and cosines of the angles, but when I do (and I make appropriate approximations) I'm left with no dot{\theta} or dot{\phi}terms which doesn't seem right.
But I'm also not sure if it's as simple as T=ml^2(dot{\theta}+dot{phi}).
Thanks
The easiest thing to do is simply write down the x and y coordinates of the center of mass of the rod in terms of the two angles and then calculate ##\frac{1}{2}(\dot{x}^2+\dot{y}^2)##.
Thanks. A new question though:
What is ω (from the rotational KE) in terms of the two angles? Usually \omega = dot{\theta}. But that's only for one angle. Because if ω isn't in terms of the angle(s) then the rotational KE drops out when you take the derivatives for L which doesn't seem right.
Thanks again.
From the way you defined the angles, you should have ##\omega=\dot{\phi}##, right? Changing that angle corresponds to the bar rotating whereas changing ##\theta## only causes translation of the bar.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
