How can i obtain the pump flow rate ?
To obtain the pump flow rate, the most reliable method is to refer to the manufacturer's pump curves, which relate pump head to flow rate. Alternatively, the bucket and stopwatch method can be used for a straightforward measurement by filling a known volume and timing the process. For low flow applications, an electronic meter with a propeller is a cost-effective option, while a pressure differential device is suitable for high flow scenarios. Eddy current flow meters are user-friendly but come at a higher cost. Understanding these methods allows for accurate determination of pump flow rates.
maxx_payne
how can i obtain the pump flow rate ?
is this done by filling a certin volume and measure time or there is another method ??
Pump curves from the manufacturer is the best way. The pump head and flow rate are related so you'll need to have the curves.
You can get the rated flow rate by using the bucket and stop watch method though! :wink:
CS
Pump flow rate can be obtained by following engineering device:
1. for low flow, electronic meter with a propeller will help you; cheapest flow meter.
2. for high flow, pressure diffential device is a mechanical choice.
3. eddy current flow meter, easy to use, no skill is need but very expensive.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
