How can we have Inelastic scattering?
In summary, inelastic scattering is a type of scattering event that produces heat through the vibration of target particles. This differs from elastic scattering, where the translational kinetic energy of the scattered particles is conserved. In inelastic collisions, some of the kinetic energy may be converted into internal energy, such as vibrational or rotational energy. However, this internal energy is not included in the calculation of the translational kinetic energy of the object as a whole. In some cases, inelastic collisions may also result in the production of new particles, consuming some of the kinetic energy.
hokhani
483
Inelastic scattering is the scattering event in which heat is produced. But we know that heat is also due to particles' vibration. Therefore when the vibration is made in target by incident particle, the target would vibrate (in other words, phonons or heat are produced). Thus heat is a type of vibration. So what is the difference between elastic and inelastic scatterings?
Science news on Phys.org
The difference is in whether or not the translational kinetic energy of the scattered particles in conserved. If it is elastic scattering, the kinetic energy of the scattered particles will be the same as that of the incident particles. If not, then the collisions are inelastic.
total energy is always conserved though.
hokhani said:
Inelastic scattering is the scattering event in which heat is produced. <snip>
Not always: kinetic energy can also be converted into changes of 'internal' energy (vibrational, rotational, electronic, spin) states. This is how He-Ne lasers work, for example.
Ok,thank you very much, But how about inelastic collision? According to the fact that heat is anyhow a type of vibration how can we have inelastic collision?
This internal vibrations are excluded from the computation of the translational kinetic energy of the object as a whole which uses the speed of the center of mass, not the speed of each individual particle. That part of the kinetic energy belongs with the internal energy (thermal energy).
By this you mean that: If we have two single particles (such as electron), we would only have elastic collision and inelastic collision is not possible. Ok?
Yes, except that if the energy of the collision is high enough, you would start producing new particles by pair-production and that process would consume part of the kinetic energy, than you would have inelastic collision between electrons.
Likes 1 person
Related to How can we have Inelastic scattering?
1. How does inelastic scattering occur?
Inelastic scattering occurs when a particle or photon collides with another particle or atom and transfers energy to it, causing it to vibrate or undergo a change in energy state.
2. What types of particles can undergo inelastic scattering?
Any type of particle or photon can undergo inelastic scattering, including electrons, protons, neutrons, and photons of various wavelengths.
3. What are the applications of inelastic scattering?
Inelastic scattering is used in a variety of applications, including spectroscopy, material analysis, and medical imaging.
4. How is inelastic scattering different from elastic scattering?
In elastic scattering, the colliding particles or photons transfer energy without changing their energy states. In inelastic scattering, the energy transfer causes a change in energy state.
5. How can we control the amount of energy transfer in inelastic scattering?
The amount of energy transferred in inelastic scattering can be controlled by adjusting the energy of the incoming particle or photon and the properties of the target material.
  • Astronomy and Astrophysics
  • Atomic and Condensed Matter
