How does one integrate u√(1+u^2) du?
  • Thread starter Thread starter Rosebud
    Integrate
Rosebud
Forget what u is being substituted for. It doesn't really matter right now. I just need to integrate what is typed above.
I am completely lost and not sure what to do.
What's the derivative of 1+u2 ?
The derivative of 1+u^2 with respect to u is 2u du.
I know the answer is (1/3)(1 + u^2)^(3/2) but I don't know how to find it.
Do you know the method of substitution ?
No.
That should have been a BIG hint.
Take the derivative of (1/3)(1 + u^2)^(3/2) . Then work backwards.
Thanks for the tip. I did that but I still fail to see the connection. Can you, or someone else, give me the next step?
Let v= 1+u^2
so dv=2u du
how do you replace du and (1+u^2)
DeldotB said:
Let v= 1+u^2
so dv=2u du
Notice you have a u in the numerator. So what can you do to replace the numerator with dv ?
Numerator? There is no fraction here unless you you consider 1 as the denominator.
ahh, thought I saw a / in front of the root.
fixed it. That partial square root symbol gets me
That helped immensely. Thank you so much. I forgot that I could use substitution more than once.
Rosebud said:
No.
So, you do know substitution.
Of course a substitution in a substitution is still one substitution overall so you can substitute twice all at once, but maybe it is better to go by stages at first. :oldsmile:
Yes, I know substitution. You asked me if I knew the method of substitution, which I understood as, you asking if I knew which method of substitution that I should use.
1 + [sinh^2(x)] = [cosh^2(x)]
