How much work from an engine?
In summary: In looking at your previous answer, you have to use the \Delta H of the reaction, not the \Delta G.Thank you for your help.
megid
An internal combustion engine operated with methanol (CH3OH) as the fuel has a thermodynamic efficiency of 20%.
a) How much work is derived from burning one mole of ethanol in the engine?
b) What is the max work that could be derived by reacting the methanol with pure oxygen in a fuel cell at 25 C?
For CH3OH + (3/2)O2 -> CO2 + 2H2)
G = -702.36 kJ at 25 C
H = -726.51 kJ at 25 C
Not too sure how to even start this problem, as I don't know what relevant thermodynamic equations I need to use. Hoping someone could please point me in the right direction.
How much energy is released from the combustion of one mole of CH3OH? That is the input energy. If the efficiency is 20%, how much of that is converted into work?
For part b) you have to figure out the combustion temperature of the methanol and then work out the maximum efficiency of a reversible cycle operating between that temperature and 25C (298K).
AM
So the energy release is -702.36 kJ and 20% of that would be -140.47 kJ which would be the work done?
Also, I haven't really a clue how to start b even after the hint you gave me... I don't know how to find the combustion temp of methanol. I'm sorry for all the questions, but I really am lost. I don't want anyone to hold my hand, because I really want to understand this.
If your figures are correct, that is correct.
If you combust one mole of methanol, how many moles of O2 do you consume? How many moles of CO2 and H2O does that combustion produce? What are the specific heats at constant volume of these products of combustion? Now add the heat energy released in that combustion and determine the resulting change in temperature: [itex]\Delta T = \Delta U/nC_v[/itex]
AM
For part b, I don't want to seem stupid, but are you sure that's the method for fuel cells? Because it seems like you're still talking about combustion engines.
The energy produced in the fuel cell is from the combustion of methanol. The fuel cell somehow turns that heat energy into electricity in an efficient way. But the maximum efficiency is determined by the thermodynamic limit, regardless of the technology. That is simply a matter of the second law of thermodynamics.
In looking at your previous answer, you have to use the [itex]\Delta H[/itex] of the reaction, not the [itex]\Delta G[/itex].
AM
1. How is work defined in relation to an engine?
Work is defined as the transfer of energy from one form to another. In the context of an engine, work is the amount of energy that is converted from the fuel source into mechanical energy to power the engine.
2. How is the work output of an engine measured?
The work output of an engine is typically measured in units of power, such as horsepower or kilowatts. This is a measure of the rate at which work is being done, or the amount of energy being converted per unit of time.
3. What factors affect the amount of work an engine can produce?
The amount of work an engine can produce is affected by several factors, including the type of fuel used, the size and design of the engine, the efficiency of the combustion process, and the operating conditions (such as temperature and pressure).
4. How does the efficiency of an engine impact its work output?
The efficiency of an engine refers to how much of the energy from the fuel is actually converted into useful work. A more efficient engine will have a higher work output, as less energy is wasted in the form of heat or other losses.
5. Can the work output of an engine be increased?
Yes, the work output of an engine can be increased by improving its design and efficiency, as well as using higher quality fuels. However, there are limitations based on the laws of thermodynamics that ultimately determine the maximum work output of an engine.
  • Thermodynamics
  • Mechanical Engineering
