I How to change CSpice initial velocity from an Asteroid SPK file?
To change the initial velocity of an asteroid using a CSpice SPK file, the user has created a file for asteroid 7482 (1994 PC1) and seeks to adjust its velocity for future position calculations. They found a solution involving C++ and Python code from a GitHub repository that implements Newtonian mechanics with a symplectic integration method. The user modified the C++ code to compute initial positions and speeds with CSpice, which are then used in conjunction with the Newton Candy method to project future distances to planets. Important considerations include ensuring proper unit conversions and using the correct CSpice frame (ECLIPJ2000) and observer settings. The discussion emphasizes the utility of APK Editor in this process.
forofo
TL;DR Summary
Change spice spk file velocity to determinate the position of an asteroid
Hello, I've made a SPK file for asteroid 7482 (1994 PC1) with Horizon. I wan't to change the initial velocity with cspice, because I want to know where it will be in a future time at the speed changed. (now I'm using Newtons calc but is slow an error increases with time). This is for calculating NEO's asteroid position desviation.
Astronomy news on Phys.org
I found the answer: In this link https://github.com/fding/nbody (Newtonian mechanics and a four-order symplectic Candy-Rozmus integration), there is c++ code and phyton. I've modify the c++, so now I calc the inital positions and speeds with cspice and pass then to Newton candy with other asteroid speed. Then I run both to the future to see the asteroid distance to any planet. Just take care about units conversion, cspice frame(ECLIPJ2000) and obverser naif Solar System(0), Used de440.bsp and 2007482(1994 PC1).bsp
You might want have APK Editor in your tool kit.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Today at about 4:30 am I saw the conjunction of Venus and Jupiter, where they were about the width of the full moon, or one half degree apart. Did anyone else see it? Edit: The moon is 2,200 miles in diameter and at a distance of 240,000 miles. Thereby it subtends an angle in radians of 2,200/240,000=.01 (approximately). With pi radians being 180 degrees, one radian is 57.3 degrees, so that .01 radians is about .50 degrees (angle subtended by the moon). (.57 to be more exact, but with...
