Inductor and electromagnetic field with voltage
In summary, an inductor is a passive electronic component that stores energy in the form of a magnetic field. It produces this field by creating a magnetic field around a coil of wire as current flows through it. The voltage across an inductor is directly proportional to the rate of change of current, known as Faraday's law of induction. Inductors resist changes in current flow, causing current to lag behind voltage changes, and are commonly used in electronic devices and power systems.
Tryp
I'm having hard time understanding how exactly current that passes through inductor transforms energy into magnetic field and then into voltage, with 90° phase shift.
I drew schemes representing sinusoidal imput current, its magnetic field and voltage relation.
Is it correct?
Would really really appreciate answer
Related to Inductor and electromagnetic field with voltage
1. What is an inductor?
An inductor is a passive electronic component that stores energy in the form of a magnetic field. It is typically made of a coil of wire and is used in circuits to control the flow of current.
2. How does an inductor produce an electromagnetic field?
When current flows through an inductor, it creates a magnetic field around the coil. This magnetic field increases as the current increases and decreases as the current decreases.
3. What is the relationship between inductance and voltage?
The voltage across an inductor is directly proportional to the rate of change of current through the inductor. This relationship is known as Faraday's law of induction and can be represented by the equation V = L di/dt, where V is voltage, L is inductance, and di/dt is the change in current over time.
4. How does an inductor affect the flow of current in a circuit?
An inductor resists changes in current flow, which means it can cause current to lag behind voltage changes. This property is known as inductive reactance and is represented by the symbol XL. It is measured in ohms and depends on the frequency of the current and the inductance of the coil.
5. What are some common applications of inductors?
Inductors are commonly used in electronic devices such as radios, televisions, and computers. They are also used in power supplies, filters, and tuning circuits. Inductors are also an essential component in motors, generators, and transformers.
  • Electrical Engineering
