I Is Spacetime infinite dimensional?
Ax_xiom
TL;DR Summary
I attempt to read a paper that is way to advanced for me and want to know what it's saying
So I found this paper while in a discussion online and I don't think I fully understand it, here's my understanding so far
  • The paper starts by recouting the string uncerainty relation
  • the paper then points out that one of the formulae used there only has a finite amount of terms, where it should have an infinite amount of terms
  • This results in there potentially being infinite dimensions
  • The paper then goes on to say that spacetime could fractal
  • Which the paper argues could result in the amount of dimensions in the universe being variable rather than fixed
So are there any holes in my understanding, if so where?
Moderator's note: Thread moved to the Beyond the Standard Models forum.
Ax_xiom said:
  • The paper starts by recouting the string uncertainty relation
Which means that it is talking about a hypothesis which has no experimental support, so whatever it says should be viewed with that in mind.
So does that mean that it's just a theory/hypothesis and spacetime doesn't necessarily have infinite/variable dimensions?
Yes.
FYI PF members submit Insight articles. This mathematics education article describing dimensions, while not directly answering the OP, should add understanding of mathematical dimensions applied in related fields.
Chapter 7 descibes Fractal Dimensions using vivid diagrams.
Likes ohwilleke and PeroK
Ok I'll look at that
And another question, is the infinite dimensions thing a view of the entire field of Quantum General Relativity or just a subset of them
What have you learned from studying this subject?
The paragraph at the top of page 6 of the cited article provides a mathematical, though not a physical, foundation using Clifford manifolds and Cantor fractals to describe spacetime. Thinking in terms of Cantor infinite sets as used by the authors, your latter answer fits. What do you conclude?
I took this lack of experimental verification and, therefore, data sets to explain replacing vector calculus with abstract algebra to continue theoretical investigation into string theory.
Infinite dimensions is a far out of the mainstream hypothesis.
It isn't necessarily a "crackpot" hypothesis. In other words, there may be a line of scientifically logically plausible arguments to support the approach, and its phenomenological implications may be subtle enough that it can't be conclusively ruled out with observational evidence.
But, the big problem with any theory that proposes more than four dimensions of GR and the Standard Model, is that you then have to explain why we observe only three dimensions of space and one dimension of time in high precision observations and experiments.
Mainstream string theory proposes 10-11 dimensions, of which all but four of them cannot be observed. Mostly, these theorist argue that this is because (1) we and all non-gravitational interactions are confined to a four dimensional brane from which only gravity can escape (which is a partial explanation for why gravity isn't closer in strength to the other fundamental forces), or (2) the dimensions in excess of 4 are "curled up" and tiny so that different locations in those dimensions are imperceptible, even in precise scientific observations.
Of course, the lack of a consensus on why we can't observe more than four dimensions in string theory, is itself notable. String theory doesn't have any definitive or final answers about reality for us at this point, and is really just a set of lots of highly similar theories that are intimately related to each other mathematically.
A hypothesis that lacks any observational support to suggest it, and makes theoretical predictions contrary to other theorists in the same subfield (i.e. string theory) do, is what is called an "ill-motivated" hypothesis.
Now the fact that a hypothesis is ill-motivated doesn't mean it is wrong. New ultra-precise instrumentation to make a novel kind of observations could provide support for this idea at any time. Given the observations available to scientists in the 1700s, both general relativity and the Standard Model of Particle physics would have been ill-motivated. The math to hypothesize them mostly already existed, but in the 1700s there were no instruments at the time that were capable of observing that phenomena that suggested them, and no one has proposed similar theories about potential new physics then.
But an ill-motivated hypothesis also doesn't provide any really compelling reason to take it seriously at this time, because even if there are "new physics" out there waiting to be discovered, there isn't much to recommend this hypothesis relative to the theoretically infinite variety of possible alternatives which are also ill motivated.
What could be wrong with the analysis?
I'll identify a few of the most obvious possibilities, although this list obviously isn't exhaustive.
Possibility one: The infinite series used isn't fundamental
But the fact that one calculates something by approximating an infinite series doesn't imply an infinite number of independent degrees of freedom.
For example, one way to calculate π is by summing up terms from an infinite series. But this doesn't imply that π (or the circles that it is a property of) has properties that are inherently tied to its infinite series representation. You could also just define a circle and the radius of a circle and use that to measure π directly without resorting to an infinite series.
Most quantities in the Standard Model which we calculate using truncated infinite series methods (typically only to a handful of loops made up of thousands to hundreds of thousands of individual terms), obviously happen in real life by some method that doesn't require some extra-dimensional computer to calculate an infinite series every time a particle moves or interacts.
There is every reason to think that the infinite series path integral approach to doing those calculations is not truly fundamental. Indeed, the fundamental way that it happens may be closer to Monte Carlo simulations which apply random chance to lots of independent agents in the model, than it is to the analytical path integral calculation that physicists use to make high precision calculations.
If there is a way to make the same calculation that doesn't involve an infinite series, then the mere fact that an infinite series can be used to make a calculation shouldn't imply that this calculation alternative implies that there are an infinite number of fundamental dimensions of space-time. The infinite number of terms in the calculation may simply be a calculation trick rather than saying anything fundamental about the nature of space and time.
As another example, it is possible to think of imaginary numbers as just a calculation trick, since no observables allow you to directly observe some quantity that has an imaginary number value, even though one can infer an imaginary numbered factor in some intermediate step in a calculation that is done to get what you observe.
Possibility two: The dimensions implied aren't truly the kind of independent and fundamental dimensions we mean when we talk about space-time being four dimensional.
Another possible issue could be that the analysis is not properly distinguishing between a loose sense of the word "dimensions" and a more strict sense of the word restricted to fundamental and irreducible dimensions that are fully independent degrees of freedom.
(Or, in the alternative, the distinction is being made properly and the true result isn't actually about the number of fundamental independent dimensions of space-time, but the term "infinite dimensional" is being used in the title as a sort of click bait to get people to read the paper which is reaching a result which has some scientific merit, but is much less awesome and amazing than its title suggests. I haven't dug into this particular paper to confirm that, but it isn't unusual for physics paper titles to imply something more awesome that the paper actually discusses, with the deflating caveats to the paper's conclusion buried away in the body text.)
As an example within the physical sciences, you can define "temperature" in a way that it is a scalar quantity across all of space-time, which looks like a fifth dimension, even though actually, it can be fully derived from the motion of particles within a four dimensional space time.
Similarly, you could model gravity as a tensor field with a sixteen element tensor value at each point in a four dimensional space-time. But because that can be fully determined from the distribution and flux of mass-energy within space-time, the gravitational tensor field isn't a true independent fundamental space-time dimension.
Outside the physical sciences, for example, such as in an economics model, it is routine to design a model in which all sorts of factors (e.g. the prices of goods in all sorts of different locations and times) are modeled as thousands of independent dimensions, even though those dimensions aren't fundamental degrees of freedom in space-time.
Possibility three: The paper is bumping into the concept of emergent dimensionality in space-time from a different perspective.
In some variations of the loop quantum gravity models of quantum gravity, space-time at the most fundamental level is conceptualized as an infinite, or near infinite (e.g. the four dimensional volume of the observable universe divided into Planck distance/Planck time chunks) set of nodes which have a finite number of connections (e.g. three or four) to other nodes. In this conceptualization concepts like the continuity of space-time, and locality, and also the number of dimensions of space-time, are only statistical approximations that emerge from a network of connected nodes that is actually more fundamental.
It would probably be possible to map this concept of emergent space-time dimensions to a model in which there are an infinite number of dimensions, but in which dimensions greater than the number of connections per node are impossible to observe for all practical purposes, because the network arrangements from which more than that number of dimensions emerge are so small and so improbable.
Thus, it could be that the infinite term series from which it is inferring an infinite number of dimensions, is really describing an infinite, or functionally infinite, number of configurations of nodes and connections that correspond to higher numbers of emergent dimensions that are increasingly less important phenomenologically, because the later terms describe systems made up of fewer nodes in less probable configurations.
With respect to the notion of infinite and functionally infinite being difficult to distinguish, Feynman, when developing renormalization, had wondered if the renormalization cutoff was just an arbitrary mathematical trick, or if there was some real physically based cutoff beyond which the infinite number of terms in an idealized path integral formulation did not extend, since the omitted terms below the renormalization cutoff were too small to make an observable difference.
Likes PeroK and Klystron
The author of this paper (Carlos Castro, now Carlos Castro Perelman), has over the decades written a large number of papers which discuss all kinds of advanced frontier topics in physics, but which themselves do not seem to be contributing results that are accepted and taken up by other authors. That is, even when they are cited, they are courtesy citations of the kind where an author writing about topic X, mentions other papers about topic X but doesn't actually engage with any of the detailed claims in those other works.
In the case of some authors who are on the margins of physics, I have studied enough of their work that I can tell you where I think they're wrong or (very occasionally) right or half-right or still have a chance of being relevant. In this case, I know the author's name from his prolificness, but I don't have any sense of the gestalt of his work.
The particular topic here refers to a generalization of Heisenberg's uncertainty principle to the context of string theory. I believe the real deal here is Yoneya's "space-time uncertainty principle". Interestingly, if I look back at the start of Carlos Castro's career, his first papers are actually about topics from string theory and supersymmetry. His magnum opus then (mid-1990s) is a paper in which a string uncertainty principle is meant to incorporate Laurent Nottale's "scale relativity", a topic which is known to a few of the old guard in this forum.
On the other hand, by the time you get to the paper from 2000 that's under discussion in this thread, he is citing Mohammed El-Naschie's "E-infinity theory". El Naschie has a terrible reputation these days, not just because his theory is considered a patchwork of ideas lacking mathematical substance (let alone empirical confirmation), but because he and some affiliated authors around the world, were publishing primarily in a journal where he himself was the editor. It would actually be mildly interesting to know Carlos Castro's opinion of El Naschie's theory these days, because he evidently engaged with the theory, yet he's intellectually independent of it.
An intellectual thread connecting all these authors (Castro, Nottale, El Naschie), incidentally, is the idea that space-time might be "fractal". Mathematically this is a valid concept, there are such things as fractal spaces. In principle, it's valid to take any consistent mathematical construct, and then ask whether it can describe the physical world or make correct predictions. The problem with a lot of high-concept fringe physics is that neither the mathematics or the empiricism is done with any rigor. At worst, you'll have a vague equation that outputs a number that appears somewhere in physical reality, but without any prospect of extending that to a complete and coherent picture. From what I recall, El Naschie is like that.
On the other hand, Castro was also a colleague of Tony Smith, another physicist who started inside the system and ended up outside, who was again known to the old guard on this forum and probably has a few friends here. Tony Smith's work was much much closer to the mainstream of grand unification, they were variations on ideas (graviGUT unification, a focus on Clifford algebras or division algebras) which still have plenty of adherents. So maybe Castro's paradigm boils down to a combination of that kind of work (one of his more popular papers is an "R x C x H x O" theory of gravity) with this "fractal space-time" concept.
Likes PeroK and ohwilleke
