Is the Andromeda Paradox accepted in physics?
In summary, the Rietdijk-Putnam argument is a paradox in physics that questions the concept of relative simultaneity and its implications on causality. It is based on the idea that different observers can see different time periods, but it does not violate causality because it is consistent with the principles of special relativity. The paradox is often misunderstood and can be resolved by having a better understanding of the concept of causality in special relativity.
  • #36
PeterDonis said:
There is no limit involved. You were describing light. Light is not the limit of anything, it's just light. @Ibix makes a valid point.
the faster something goes from A to B approaching the speed of light, the closer the perceived increment approaches zero.
  • #37
...and you can never reach light speed this way and all inertial frames are equivalent, so "approaching the speed of light" is also "stationary". So there is no valid limit as you approach the speed of light, because you aren't doing so in any meaningful sense.
Proper time is a parameter that indexes the point along a worldline. Unfortunately, it's degenerate for null worldlines and you have to use a different approach.
Likes m4r35n357 and PeterDonis
  • #38
Ibix said:
It's the mathematical abstraction you use to interpret your clock readings.
Ultimately it's like using a map. Does the world actually look like a map? No. We use maps instead of photographs to navigate because they remove the observation point dependence of the photo, and maps are an incredibly useful way to describe and communicate about terrain.
The relativity of simultaneity is analogous to your freedom to draw a map with north pointing in any direction you like. Length contraction and time dilation are consequences of that choice - analogous to a building being square or diamond-shaped, depending on your choice of north.
None of the relativistic effects are directly visible for the same reason that the world doesn't look like Google Maps. But they are very real in the same sense that a building that is square on one map is a diamond on another.
Say though if an astronaut was in a spaceship going .95c to the right, and a lightbulb turned on activating two clocks, both equal distances from the bulb. To the astronaut, the clocks are turned on simultaneously. But to a stationary observer, the clock at the back turns on first, and the clock at the front second. Both disagree on the clock readings then.
If the astronaut slowed back down and flew back to the stationary observer and got out and took both clocks with him, would they both agree on the clock readings?
  • #39
In general, no. The clocks have followed slightly different paths through spacetime. You must also consider exactly how the turnaround is done: do both clocks reverse their direction of travel at the same time using the ship frame or the stationary observer frame?
  • #40
No, they don't. Suppose Clock A reads noon. One observer will claim that when Clock A reads noon, Clock B also reads noon. The other observer will claim that it's necessary to wait some time after Clock A reads noon before Clock B reads noon.
Both observers agree that both clocks read noon.
They do disagree on the interpretation of those clock readings.
  • #41
But is the zero limit a time or a distance? It depends how you take the limit. Evidence that the limit cannot be just 'zero time'.
Likes 1977ub
