Is This a Valid Proof for the Number of Roots in a nth Degree Polynomial?
In summary, the conversation discusses a proof for the statement that for a nth degree polynomial, there will be n roots. The proof suggested using the fact that the derivative of a point will only be 0 on the vertex of that function, and that a nth degree function with n-1 vertexes must have n-1 roots. However, it was pointed out that this proof is not valid as it does not account for inflection points and ignores the possibility of multiple roots. Instead, it was suggested to use the number of sign changes to determine the maximum number of possible roots. Another possibility is to factor the polynomial into nth roots, either in the complex or real numbers.
YoungPhysicist
Insights Author
350
203
Recently I came up with a proof of “ for a nth degree polynomial, there will be n roots”
Since the derivative of a point will only be 0 on the vertex of that function,and a nth degree function, suppose ##f(x)##has n-1 vertexes, ##f’(x)## must have n-1 roots.
Is the proof valid?
Is the proof valid?
What about ##f(x)=x^2\,?##
Likes jedishrfu
It seems this kind of proof would necessarily need to be an induction proof and that your version seems to be too simple.
However perhaps @fresh_42 or @Mark44 could provide a better answer.
Have you looked online for any similar proofs?
Is the proof valid?
No. Where is the vertex of, say ##f(x) = x^3##? Does the graph of this function have 3 - 1 = 2 vertices?
Also, ##f'(x) = 3x^2## Are there 3 - 1 = 2 roots of the equation ##3x^2 = 0##?
Likes YoungPhysicist and jedishrfu
How about saying that they have two “identical” vertexes and roots?
If you count multiplicities, then you are right, but your proof doesn't work anymore. Each polynomial can be written as a product of terms ##x-z_i## where the ##z_i## are the possibly complex roots. And they do not have to be different, so they can occur multiple times.
If you change your statement to "at most degree many roots", then your idea is close to how it is usually proven. But the geometry is tricky here: what about inflection points? What if there aren't real roots between two local extrema? One normally counts the number of sign changes to determine the maximal number of possible roots. This is the better indicator than local extrema.
Kind of get the point,thanks!
Mark44 said:
No. Where is the vertexof, say ##f(x) = x^3##?
But this function doesn't have any vertices (plural of vertex) at all! I think you might be oversimplifying things, possibly limiting what you're thinking about to parabolas and power functions of even degree.
You can use the derivatives for the count of sign changes. It doesn't necessarily get you one, but if there is a sign change, there has to be a local extremum in between. Thus there are at most degree many roots.
So the proof should be:
A polynomial equation of nth degree can always be factored to nth roots like
$$(x-t)$$ for nth times where t here is a complex.
Is it like that?
Is it like that?
"Like" yes, but a bit very, very sloppy.
Let ##p(x)\in \mathbb{R}[x]## be a real polynomial of degree ##n## in one variable. Since ##\mathbb{R}[x] \subseteq \mathbb{C}[x]## we can interpret ##p(x)## as a complex polynomial, too. Then there are complex numbers ##z_1,\ldots ,z_k## such that ##p(x)=(x-z_1)^{n_1} \cdot \ldots \cdot (x-z_k)^{n_k}## and ##n_1+ \ldots + n_k =n\,.## Especially we have ##k \leq n\,.##
This is one possibility. The other is to stay in ##\mathbb{R}[x]## and observe, that the limits of ##p(x)## for ##x \to \pm \infty ## are also ##\pm \infty##. Therefore there is a first and a last zero (or none). Every time the graph of ##p(x)## crosses the ##x-##axis, we get a sign change in ##p(x)##. However, between two of those sign changes, there has to be at least one point with ##p'(x)=0##, maybe more. By induction we know, that at most ##n-1## such locations are possible. So the ##n-1## in betweens mean at most ##n=(n-1)+1## possible zeroes.
To essentially iterate what fresh has said, you can use the principle that a graph cannot change direction between two consecutive critical points (zeroes of the derivative). Hence at most one zero of the function can occur between any two zeroes of the derivative. Thus the function has at most one more zero than its derivative.
To prove the first principle stated, use the fact that a local extremum must occur on any interval where the function changes direction.
Since also a function's derivative must have a zero between any two consecutive zeroes of the function, the derivative must also have at least one fewer zeroes than the function itself. This proves again that if the function has n zeroes, the derivative has at least n-1 zeroes. This is the same proof "said backwards". Both proofs rest on the same somewhat deep fact, that a continuous function has a local extremum on any interval on which it takes the same value at both ends.
Note however the derivative can have more zeroes than this. for e.g. X^2 + 1. the derivative actually has more zeroes than the function itself.
A proof by algebra, as suggested above, uses only the basic "factor theorem", that if x=a is a root of the polynomial f(x), then (x-a) is a factor. It follows, since factoring f(x) out by (x-a) lowers the degree, that f(x) can have at most deg(f) factors, hence also at most deg(f) roots. This proof assumes only that we are working in a realm of numbers where the product of two non zero numbers is again non zero.
The short answer is no. This theorem is only true when complex numbers are allowed. It looks like you are working in the Reals, in which case it is false. It is difficult to prove something that is false.
Likes YoungPhysicist and Delta2
Proving it's false is the proof in this case.
Because the theorem is so important, I think that it is good to simply state that it is true over the complex numbers, but not over the reals. The proposed proof does not make any sense in the complex plane.
Due to multivalueness?
No. I'm not sure which part of my statement you are asking about, but multivaluedness is not the basic problem. The OP seems to say that the real derivative and geometry on the real line is enough to prove the Fundamental Theorem of Algebra, but it is not -- it is not true on the real line and the proof is more complicated over the complex plane. For correct proofs of the Fundamental Theorem of Algebra, see https://en.wikipedia.org/wiki/Fundamental_theorem_of_algebra#Proofs
Multiple zeros is not the problem. As @mathwonk pointed out, ##x^2+1## has two distinct zeros, ##\pm i##, in the complex plane, but no zeros on the real line. How does the proposed "proof", which is completely without detail, reach a conclusion about that polynomial based on its derivative, ##2x##?
I do not disagree
Likes FactChecker
What do y
Is the proof valid?
Mean by vertex of the function?
1. What is a valid proof?
A valid proof is a logical and systematic demonstration of the truth or validity of a statement or theorem. It follows a set of rules and principles of logic to establish the validity of a claim.
2. How do I know if a proof is valid?
A proof is considered valid if it follows a logical and consistent sequence of steps that lead to the conclusion. It should also follow the rules of the specific field or subject it pertains to.
3. What are the essential elements of a valid proof?
The essential elements of a valid proof include a clearly stated hypothesis, a set of assumptions or axioms, a logical sequence of steps, and a conclusion that logically follows from the previous steps.
4. Can a proof be valid but not true?
Yes, a proof can be logically valid but not necessarily true. This can happen if the initial assumptions or axioms used in the proof are not accurate or if the logic used is flawed.
5. How can I improve my ability to create valid proofs?
The best way to improve your ability to create valid proofs is to practice and familiarize yourself with the principles of logic and the rules of the specific field or subject you are working in. You can also seek feedback from peers or experts in the field to identify areas for improvement.
