Kinetic Energy & Intrinsic Angular Momentum
In summary: The derivation is reasonably elementary in that it only uses the concept of work = force x distance. You can also look at it as follows. Imagine moving an object up in a gravitational field. As it moves it gains potential energy. In a uniform field it must gain the same energy for every ##1m## it is raised. Why? Because every ##1m## up is just the same as the ##1m## before and the ##1m## after.The GPE (gravitational PE) must be proportional to the height it is raised. It turns out that it is ##mgh##, but any constant times ##mh## would do.You
metastable
514
53
I had a question about the equation (1/2)mv^2...
Why is the velocity squared? Why not simply (1/2)mv? Does it have anything to do with the intrinsic angular momentum ie does the intrinsic angular momentum change in anyway as velocity increases in a particular reference frame leading to the squaring of velocity in the (1/2)mv^2 KE equation?
##mv## is the magnitude of momentum.
There are a number of ways to derive the equation for kinetic energy. Have you looked online for one of them?
I have looked through the wikipedia article on KE, but still trying to understand why a doubling of velocity means a quadrupling of the energy.
PeroK said:
Interesting article... it states:
  • Kinetic energy depends on the velocity of the object squared. This means that when the velocity of an object doubles, its kinetic energy quadruples. A car traveling at 60 mph has four times the kinetic energy of an identical car traveling at 30 mph, and hence the potential for four times more death and destruction in the event of a crash.
So I understand a car traveling twice as fast has 4 times as much KE... but I'm not sure if it answers my original question...
Does it have anything to do with the intrinsic angular momentum ie does the intrinsic angular momentum change in anyway as velocity increases in a particular reference frame leading to the squaring of velocity in the (1/2)mv^2 = KE equation?
It has nothing to do with intrinsic angular momentum.
The page I linked to explained it all - unless you skipped over the maths!
If we use : W=m⋅d⋅((vf^2−vi^2) / 2d) from the article the velocity is squared as well. Perhaps I am asking a question with no real answer ie there is no "why..." it just is the way it is and there's an equation that describes it.
You also have the kinematic formula ##v^2 = 2gh##, which can be derived simply, for an object falling from rest under constant gravity.
Hence ##v^2## and not ##v## must be proportional to GPE. And, hence, you have ##v^2## in the formula for KE.
Likes anorlunda
Also, early work studying the depth of indentions in soft clay showed that the depth was proportional to v^2.
I have no idea how angular momentum came into this thread. It is completely unrelated as far as I can see.
1. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is calculated by the mass of the object multiplied by the square of its velocity, divided by 2 (KE = 1/2 * m * v^2).
2. What is the difference between kinetic energy and potential energy?
Kinetic energy is the energy an object possesses due to its motion, while potential energy is the energy an object possesses due to its position or state. Kinetic energy can be converted into potential energy and vice versa.
3. How is kinetic energy related to momentum?
Kinetic energy is directly proportional to momentum. This means that as the kinetic energy of an object increases, its momentum also increases.
4. What is intrinsic angular momentum?
Intrinsic angular momentum, also known as spin, is a fundamental property of particles that determines their angular momentum even if they are not physically spinning. It is a quantum mechanical property that cannot be explained by classical physics.
5. How does intrinsic angular momentum affect the behavior of particles?
Intrinsic angular momentum affects the behavior of particles by determining their spin, which is a fundamental property that affects their interactions with other particles and their behavior in certain physical phenomena, such as magnetism.
  • Mechanics
  • Mechanics
