Lightning bolt charge physics problem
A lightning bolt with a current of 30,000 A lasts for 50 microseconds, resulting in a total charge of 1.5 C deposited. The attempt to calculate the charge on the airplane at 20,000 ft involved integrating current over time, but the approach was unclear. The correct method to find the charge is using the formula q = it, confirming the charge from the lightning bolt. The user seeks clarification on how to accurately determine the charge deposited on the airplane. Further guidance on the physics involved would be beneficial for resolving the problem.
seraphimhouse
A lightning bolt carrying 30,000 A lasts for 50 microseconds. If the lightning strikes an airplane flying at 20,000 ft, what is the charge deposited on the plane?
q(t) = \int i(x)dx
So, using the equation above I found the charge of the lightning bolt to be 30,000A * 50 x 10^-6
q(t) = 1.5 c
Then to find charge of the airplane
q(t) = \int 20,000dx from 0 to 50 microseconds
q(t) = 20,000x
q(t) = 20,000 (50 x 10^-6) = 1
I'm a bit rusty on my physics as you can see. Maybe someone can direct me to a more precise approach. Thank you
x is not time i guess
i could find the charge of the lightning bolt by q = it given i = 30,000 A and t = 50 x 10^-6 s
q = 30,000A) * (50 x 10^-6 s) = 1.5 C
but how can I find the charge deposited onto the plane at 20,000 feet?
