Who Threw the Ball First in This Physics Puzzle?
In summary: The problem specifies that the top person catches it on the way up, so the time will be the first time.
snowsnowrain
A child stands on a balcony directly above a friend 5.00
m below. Each throws a ball toward the other with the
same initial speed of 10.0 m/s. If each catches a ball at
the same instant, which child threw a ball first? How
much later was the second ball thrown?
I used x = xi + vi(t) + 1/2(a)(t^2)
Where x is the vertical distance.
By just thinking about the question, the person below the balcony should throw the ball first if both people catch balls at the same instant.
I'm not sure if vf can equal 0 m/s or not so I used x= xi + vi(t) + 1/2(a)(t^2).
I let the positive x be upward.
Bottom person:
x = +5.00 m
xi = 0
vi = +10 m/s
a = -9.81 m/s^2
-4.905(t^2) + 10(t) - 5
Used the quadratic formula to get t = .87885 sec, 1.159878
Top person:
x = 0.00 m
xi = 5.00 m
vi = -10 m/s
a = +9.81 m/s^2
4.905(t^2) - 10(t) + 5
But doing this makes the t for top person and t for bottom person equal the same.
snowsnowrain said:
Top person:
x = 0.00 m
xi = 5.00 m
vi = -10 m/s
a = +9.81 m/s^2
Why has gravity flipped for the top person?
One of them will be throwing the ball with the help of gravity and I think it should be the top person.
Gravity points in the same direction regardless of which way the ball is thrown.
Your intuition about the ball being thrown "with the help of gravity" is manifest in the fact that the initial velocity and gravity will have the same direction (both negative). The direction of gravity will not be reversed though.
Thanks a lot. I figured out the top persons time to equal 0.415 sec using the quadratic formula.
I use the bottom time - top time = How much later the second ball was thrown.
If my equation for the bottom person is correct, how am I suppose to know which time value to use? Will it always be the first time (lowest time value)?
If you imagine the path of the bottom person's ball if the the top person did not catch it: it will go up past the top person, and then come back down past the top person. So the smaller time will be when it first passes the top person (on the way up) and the larger time will be when it again passes the top person (on the way down).
The problem actually didn't specify that the top person catches it on the way up, so in that sense there are multiple solutions. If I had to guess, I would say they want you to assume that it is caught on the way up, but if so then they should've said something about that.
Likes snowsnowrain
Thanks a lot. You've been very helpful.
What is Linear Kinematics?
Linear kinematics is the study of motion of objects along a straight line, without considering the forces that may be acting on the object.
What are the basic equations of Linear Kinematics?
The basic equations of linear kinematics include displacement (Δx = xf - xi), velocity (v = Δx/Δt), and acceleration (a = Δv/Δt).
How is Linear Kinematics different from other branches of Physics?
Linear kinematics specifically focuses on the motion of objects in a straight line, while other branches of physics may consider motion in multiple dimensions or the forces that are acting on the object.
What are some real-life applications of Linear Kinematics?
Linear kinematics is used in various fields, such as engineering, sports, and transportation. For example, engineers use linear kinematics to design and analyze the motion of machines and structures, while athletes use it to improve their performance in sports like track and field.
How can Linear Kinematics be used to solve problems?
To solve a problem using linear kinematics, you would first identify the known and unknown variables, then use the appropriate equations to solve for the unknown variable. It is important to pay attention to units and use the correct equations for the given situation.
