How Do Longitudinal Waves Behave on a Taut String?
In summary, the problem deals with a taut string with uniform mass density and equilibrium tension. Longitudinal waves are possible if the string tension varies. The equation for small oscillations is given by 1/t_0 = (1/L)(deltaL/deltaT) and the velocity of the waves can be found through calculations involving the force and acceleration. The method is consistent for tangential waves but may have difficulties with longitudinal waves due to varying tension across the string.
Gianni2k
Hi guys, this is Barton Zwiebach's Introduction to String theory question 4.2 on the longitudinal wave on a taut string. The problem is purely classical and I seem to obtain a solution which seems far too complicated for me. If anyone has the answers it would be great, if not just your help would be amazing. For people that don't have the book this is how the question goes.
"Consider a string with uniform mass density mu_0 stretched between x = 0 and x = a. Let the equilibrium tension be T_0. Longitudinal waves are possible if the string tension varies at it stretches or compresses. For a piece of this string with equilibrium length L, a small change in its length deltaL is accompaigned by a change in the tension deltaT where:
1/t_0 = (1/L)(deltaL/detaT)
where t_0 is a tension coefficient with units of tension. Find the equation governing small longitudinal oscillations of the string. Give the velocity of the waves."
many thanks.
Just so you know what I did is calculate the general form of T(L):
T(L) = t_0 ln(L/a) + T_0
Then find the force on an infinitesimal stretch of the string then finally equate this to the acceleration via Newton's second law. The method is consistent for tangential waves but I have problems with longitudinal ones where the tension varies across the string.
Related to How Do Longitudinal Waves Behave on a Taut String?
What are longitudinal waves on string?
Longitudinal waves on string are a type of mechanical wave that travels through a medium, such as a string, by causing particles in the medium to vibrate parallel to the direction of the wave's motion.
What factors affect the speed of longitudinal waves on string?
The speed of longitudinal waves on string is affected by the tension, length, and density of the string. The higher the tension and density, and the shorter the string, the faster the waves will travel.
How are longitudinal waves on string different from transverse waves?
Longitudinal waves on string differ from transverse waves in that the particles in the medium vibrate parallel to the direction of the wave's motion, whereas in transverse waves, the particles vibrate perpendicular to the direction of the wave's motion.
What are some real-life applications of longitudinal waves on string?
Longitudinal waves on string have various practical applications, such as in musical instruments, where the vibrations of the strings produce sound waves, and in seismic exploration, where they are used to detect and study underground geological structures.
How are longitudinal waves on string measured and analyzed?
The characteristics of longitudinal waves on string, such as wavelength, frequency, and amplitude, can be measured and analyzed using techniques such as strobe photography, frequency analyzers, and oscilloscopes.
  • Beyond the Standard Models
