How Do You Calculate the Length of the Curve from $x=\ln{4}$ to $x=\ln{5}$?
In summary: No, that's the entire radicand...observe:1+\left(\frac{2e^x}{e^{2x}-1}\right)^2=\frac{\left(e^{2x}-1\right)^2+4e^{2x}}{\left(e^{2x}-1\right)^2}=\left(\frac{e^{2x}+1}{e^{2x}-1}\right)^2=\coth^2(x)
karush
MHB
3,269
$\textsf{12 Find the length of the curve $y=\ln(e^x-1)-\ln( e^x+1 )$
from $x=\ln{4}$ to $x=\ln{5}$}$
ok I thot that curve lengths were done with parametric equations
but didn't know how to convert this
I would use the formula:
\(\displaystyle s=\int_a^b \sqrt{1+\left(\d{y}{x}\right)^2}\,dx\)
You could parametrize the curve like so:
\(\displaystyle x(t)=e^t\)
\(\displaystyle y(t)=\ln(x(t)-1)-\ln(x(t)+1)\)
And then use the formula:
\(\displaystyle s=\int_{x(a)}^{x(b)} \sqrt{\left(\d{x}{t}\right)^2+\left(\d{y}{t}\right)^2}\,dt\)
$\displaystyle
\frac{dx}{dy}(\ln(e^x-1)-\ln(e^x+1))
=\frac{2e^x}{e^{2x}-1}$
$\displaystyle s=\int_{\ln 4}^{\ln 5}
\sqrt{1+\left(\frac{2e^x}{e^{2x}-1}\right)^2}\,dx$
this??
got confused on dy/dx
karush said:
$\displaystyle
this??
What you have so far looks good...now combine the terms in the radicand...:)
= \int_{\ln 4}^{\ln 5}
\sqrt{1-\csch^2(x)} \,dx $
not sure if this was a good alt choice
I don't think those two radicands are equivalent. Can you show you work to justify it?
I used W|A
this was the input
1+-(\frac{2e^x}{e^{2x}-1})^2
but isn't that just squaring the second term?
there still is a +1
there still is a +1
\(\displaystyle 1+\left(\frac{2e^x}{e^{2x}-1}\right)^2=\frac{\left(e^{2x}-1\right)^2+4e^{2x}}{\left(e^{2x}-1\right)^2}=\left(\frac{e^{2x}+1}{e^{2x}-1}\right)^2=\coth^2(x)\)
1. What is M2215.12 length of curve?
M2215.12 length of curve refers to a specific calculation used in mathematics and engineering to determine the length of a curved line.
2. How is M2215.12 length of curve calculated?
The M2215.12 length of curve is calculated using a mathematical formula that takes into account the radius and degree of the curve, as well as other factors such as the units of measurement.
3. Why is M2215.12 length of curve important?
The M2215.12 length of curve is important because it allows scientists and engineers to accurately measure and design curved structures such as roads, bridges, and pipelines. It is also used in fields such as computer graphics and animation.
4. Can M2215.12 length of curve be applied to any type of curve?
Yes, M2215.12 length of curve can be applied to any type of curve, including circles, parabolas, and spirals. As long as the necessary information, such as the radius and degree, is known, the calculation can be performed.
5. Are there any limitations to using M2215.12 length of curve?
While M2215.12 length of curve is a useful calculation, it does have limitations. It is only applicable to smooth, continuous curves and may not be accurate for irregular or jagged shapes. Additionally, it does not take into account other factors such as terrain or elevation changes.
  • Calculus
  • General Math
