M2215.14 carbon-14 dating
  • MHB
  • Thread starter karush
In summary, the conversation discusses the age of a tree that was killed in a volcanic eruption. The charcoal from the tree contained 62.8% percent of the carbon-14 found in living matter. By using the half-life of carbon-14 (5700 years), it was calculated that the tree is approximately 3826 years old. The conversation also mentions a general formula for calculating the age of an object using the percentage of carbon-14 present.
karush
MHB
3,269
$\textsf{ The charcoal from a tree killed
in a vocano eruption }$
$\textsf{contained 62.8% percent of the carbon-14 found in living mater.}$
$\textsf{How old is the tree, to the nearest year? }$
$\textsf{Use $5700$ years for the half-life of carbon-14} $
$$1=2e^{k\cdot 5700}$$
$$k=-0.00012160$$
presume this is how we find $ k$
$$62.8=100e^{-0.00012160y}$$
$$y\approx 3826$$
Mathematics news on Phys.org
If $A$ is the age of the tree (in years), and $P$ is the percentage of the original amount of carbon-14 still present and $H$ is the half-life of carbon-14 (in years), then I would write:
\(\displaystyle P=100\left(\frac{1}{2}\right)^{\Large{\frac{A}{H}}}\)
What do you get when you solve for $A$ (which is what we're asked to find)?
$$62.8=100\left(\frac{1}{2}\right)^{a/5700}$$
$$a=3826$$
why not use $y$ instead $a$?
$$a=3826$$
What I meant was to take:
And solve for $A$:
\(\displaystyle \frac{100}{P}=2^{\Large{\frac{A}{H}}}\)
\(\displaystyle A=H\log_{2}\left(\frac{100}{P}\right)\)
Now plug in the given data (we have a general formula now for other problems):
\(\displaystyle A=5700\log_{2}\left(\frac{100}{62.8}\right)\approx3826\)
Whatever you choose is fine. :)
1. What is carbon-14 dating?
Carbon-14 dating, also known as radiocarbon dating, is a method used by scientists to determine the age of organic materials. It relies on the fact that carbon-14, a radioactive isotope of carbon, decays at a constant rate over time.
2. How does carbon-14 dating work?
The process of carbon-14 dating involves measuring the amount of carbon-14 in a sample of organic material and comparing it to the amount of stable carbon isotopes. By knowing the rate of decay of carbon-14, scientists can calculate the age of the sample.
3. What are the limitations of carbon-14 dating?
Carbon-14 dating is most effective for samples that are less than 50,000 years old. Beyond this time frame, the amount of carbon-14 remaining in a sample is too small to accurately measure. Additionally, contamination and human error can affect the accuracy of carbon-14 dating.
4. How accurate is carbon-14 dating?
Carbon-14 dating is generally accurate within a range of a few hundred years. However, it is important to note that the accuracy of the dating depends on the quality of the sample and the calibration of the equipment used.
5. What are some common uses of carbon-14 dating?
Carbon-14 dating is commonly used in archaeology and geology to determine the age of ancient artifacts and geological formations. It is also used in the fields of biology and environmental science to track the movement of carbon through ecosystems and to study the effects of climate change.
9K
