MHB Man on ladder wishes to avoid the ladder slipping
  • Thread starter Thread starter Joe_1234
    Slipping
The discussion revolves around calculating the coefficient of friction required to prevent a ladder from slipping while a man climbs it. The ladder, weighing 350N and positioned at a 30° angle, must support an additional weight of 900N from the man. Participants are analyzing the forces acting on the ladder, including friction between the floor and the ladder, as well as friction between the wall and the ladder, which is noted to be 0.20. The equilibrium conditions are established with the equations for forces and torque. The conversation emphasizes the importance of understanding the direction of wall friction in this scenario.
Joe_1234
A 6 m ladder weighs 350N and is placed with its lower end on a horizontal floor and its upper end against the wall. The angle between the wall and the ladder is 30°. A man weighing 900N is to climb to the very top of the ladder. The coefficient of friction between the floor and the ladder to avoid the danger of slipping is?
Mathematics news on Phys.org
Can you show what you have so far so we know where you're stuck?
I have this diagram, but I'm not sure about this 900 N, on top of the ladder already?
$\sum F_x = 0$, $\sum F_y = 0$, and $\sum \tau = 0$
I forgot there is friction between the wall and the
I forgot there is a friction between the wall and the ladder which is 0.20
Which direction do you think the wall friction acts on the ladder?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
