Maximal left ideal of matrix ring
In summary, the conversation discusses the properties of a matrix ring R over a finite field F_q, specifically that R is isomorphic to the ring of n-by-n matrices over F_q. The first statement states that every matrix of rank n-1 in any maximal left ideal of R generates the maximal left ideal. The second statement further explains that the number of matrices in every maximal left ideal that can be a generator is equal to the number of generator matrices in the maximal left ideal, which can be represented as RE_{11}+...+RE_{n-1,n-1}, where E_{ij} is an n-by-n matrix with the ij-th element being 1 and all other elements being 0. The conversation ends with
xixi
let R be a matrix ring over a finite field [tex]\LARGE F_{q}[/tex] , i.e. [tex]\Large R=M_{n}(\LARGE F_{q})[/tex]. then
1.Every matrix of rank n-1 in any maximal left ideal generates the maximal left ideal.
2.moreover,the number of matrices in every maximal left ideal that can be a generator is the same as the number of the generator matrices in the maximal left ideal [tex]\LARGE RE_{11}+...+RE_{n-1,n-1}[/tex] (where [tex]\LARGE E_{ij}[/tex] is n*n matrix whose ij th element is 1 and the others are 0)
what is the proof of the above statements .
Thanks
What is a maximal left ideal of a matrix ring?
A maximal left ideal of a matrix ring is a subset of the ring that is closed under addition, multiplication by elements in the ring, and contains no other proper left ideals. In other words, it is a subset that is as large as possible without being the entire ring.
How are maximal left ideals related to matrix rings?
Maximal left ideals are a type of ideal that can be found in matrix rings. Specifically, a maximal left ideal of a matrix ring is an ideal that is maximal among all left ideals of that ring.
What is the significance of maximal left ideals in matrix rings?
Maximal left ideals are important in matrix rings because they can help us understand the structure of the ring. They can also be used to define quotient rings, which are important in abstract algebra and linear algebra.
How can one determine if a subset of a matrix ring is a maximal left ideal?
To determine if a subset of a matrix ring is a maximal left ideal, one must check if the subset satisfies the properties of an ideal and is not a proper subset of any other left ideal in the ring. This can be done by using the definition of a maximal left ideal or by using specific criteria for maximal left ideals in matrix rings.
Are there any other types of ideals in matrix rings besides maximal left ideals?
Yes, there are other types of ideals in matrix rings, such as left ideals, right ideals, and two-sided ideals. Maximal left ideals are just one specific type of ideal that can be found in matrix rings.
  • Linear and Abstract Algebra
